Crossfire TBI-How does it work?
Old Jan 25, 2010 | 01:36 PM
jtraynor86's Avatar
Car: 1983 T/A
Engine: 454 BBC
Transmission: Built 700R4
Axle/Gears: Weak 10 Bolt/3.23
I have an 83 trans am with the crossfire TBI 305. Can anyone please explain how this works? How do they work at cold start. My rear tb is open at cold start while my front tb won't move from being closed. My car won't start and I was thinking that this could be why. Any information is greatly appreciated.
Old Jan 25, 2010 | 02:36 PM
Ronny's Avatar
Re: Crossfire TBI-How does it work?
Q: My rear tb is open at cold start while my front tb won't move from being closed.
I will asume you are refering to the IAC's and not the buterflies. Sounds like one of the IAC's is defective. But my car always started on one of two open just idled lower RPM when cold on coolant. You could try cleaning it but odds are it is shot.
Old Jan 25, 2010 | 02:40 PM
Twin_Turbo's Avatar
If you mean the IACs they are wired in parallel and should both be in the same position at all times.
Old Jan 25, 2010 | 02:48 PM
Ronny's Avatar
You can cycle the IAC's with engine off to check their operation while looking down the TB. Dont know offhand which ALDL terminal to jump to ground. A search should find it.
I believe it is A and B. The two that are upper far right
Old Jan 25, 2010 | 03:25 PM
jtraynor86's Avatar
Car: 1983 T/A
Engine: 454 BBC
My front butterfly is closed while my rear is about half way open. Where can I see if I have a faulty IAC?
Old Jan 25, 2010 | 03:33 PM
Ronny's Avatar
OK. something very wrong. I cant imagine being that far out. Way out of adjustment or linkage defective. IAC is not your problem. The IAC attaches to TB unitand is a "stepper" motor. It retracts a pindle to allow a controlled VAC leak allowing a change in RPM. you can see it by looking down the bore into an area that is cast into TB unit. Appears black and is tapered as a cone like "pindle".
Old Jan 25, 2010 | 03:37 PM
Twin_Turbo's Avatar
Yes, putting it in field service mode will cycle the IACs
But you mean the throttle blades themselves, what happened is someone messed with the synchro screw. It's the screw on the center linkage, OEM it has a collar over it that is brazed to prevent tampering. The brazing must have been broken, maybe the entire collar is missing.
The synchro screw works by moving one blade in respect to the other by lengthening/shortening the center link. How you do it is all relative, what matters is one blade's idle stop screw (on back of TB behind a little plug if not tampered with yet) and the other is adjusted off that.
Do a search on synchronizing CFI TBs. You'll need to build a small water manometer or do it with a feeler gauge (manometer = better). Too much to quickly type down here.
What you can do is turn the screw so that both TBs are open by about the same amount, at leas it should be sort of drivable as it is now the fuel delivery across the cyls is all out of whack.
Old Jan 31, 2010 | 08:44 PM
jtraynor86's Avatar
Car: 1983 T/A
Engine: 454 BBC
Okay, changed the plugs and the car is running. It seems like it is idling really high though. Could that be because of the cold start or something else. Reads to be idle at about the 20 mark and seems to idle higher as it continues to run. Man what is up with this?
Old Feb 1, 2010 | 11:20 AM
Ronny's Avatar
check vacuum leak?
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Aug 17, 2015 02:52 PM
3rdgenparts
Aug 6, 2015 09:03 AM
