Lifters
Old Jan 31, 2010 | 08:16 PM
camaro1992's Avatar
Car: 92 RS Camaro
Engine: V8 5.0 TBI
Lifters
I have a 92 Camaro RS. I am looking into replacing my ticking lifters. I need to know what kind I have. Do I have hydraulic flat tapet? My enigne code is E, 305 V8. I think that is what I have. Thanks for the help.
Old Jan 31, 2010 | 09:27 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Re: Lifters
Read.
http://ezinearticles.com/?How-to-Adj...ers&id=1820839
Many members (myself included) have explained numerous times how to adjust lifters.
A search would help.
Your lifters need to be adjusted, not replaced.
Old Feb 2, 2010 | 10:29 PM
bear88ss's Avatar
Car: 88MCSS/92Firebird
Engine: 421/355
Transmission: TH-350/4L60
Axle/Gears: 4.11/2.73
Re: Lifters
If it is still the factory engine it is a hydraulic roller. Odds are if it is a lifter that is causing the noise it doesn't need to be adjusted from driving around, only after you pull it apart. If it is a lifter that is causing the tick, it probably just won't pump up correctly or could have jacked up the dogbone it sits in from sludge buildup from being parked for a long time then started up and driven without a teardown inspection/ cleaning.
tyeo098
Nov 30, 2015 06:27 PM
codeysabatini
Nov 10, 2015 04:07 PM
skinny z
Oct 5, 2015 06:23 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
dimented24x7
Sep 6, 2015 03:51 PM
