454 in an 88K5 Blazer
Old Feb 3, 2010 | 11:56 AM
SanitysBane's Avatar
Hey mods if this isn't in the right area feel free to move it.
I just bought this 88K5 Blazer that has a 350 with a spun rod bearing and I have a built 454 that I am planning on putting in this thing. So here is the question, what all is required to put the TBI on the 454? Also who is a good chip burner?
Engine is as follows:
454 bored .030 over
10.2:1 compression
GM Iron Oval Port heads casting # 336781 with slightly larger valves and pocket porting
1.8:1 Harland Sharp Roller Rockers
Crane Cam, grind H-286-2 (Link-
http://cranecams.com/?show=browsePar...tType=camshaft )
Edelbrock RPM Arigap intake
Thanks guys!
Old Feb 3, 2010 | 04:49 PM
Ronny's Avatar
Re: 454 in an 88K5 Blazer
TPI fuel pump is a good idea
GM 7.4 L TBI unit with 80 lbs injectors or small injectors at higher FP
Aftermarket FPR
Correct knock sensor
Correct ignition module ?not sure?
carb intake with 7.4L plate or aftermarket manifold(? do they make a 7.4L TBI?) or GM 7.4L manifold. Airgap maybe not so good choice
First choice is a DIY tune it will run better with your efforts
Second choice is tbichips.com Brian Harris
Old Feb 3, 2010 | 09:12 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
Brian Harris for sure. 1-336-471-2827
Tell him Sean from tbiparts.com sent you. He will take great care of you.
Good luck with the build. Need anything please give me a call or PM me thanks!
Sean
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
85 Jimmy
Sep 30, 2015 07:56 AM
Mongoose462ci
Sep 16, 2015 11:46 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
cRoe4
Aug 7, 2015 08:46 PM
