91 camaro idling high and low
Old Feb 24, 2010 | 01:32 PM
anthonyrs's Avatar
Car: 1991 CAMARO RS,1997 FORD EXPLORER
Engine: NO MORE 305. 350 NOW
Axle/Gears: 273 NEED NEW ONES
hi i have a 1991 camaro rs 305 tbi. just rebuilt to stock except cam,headers,no cat,chip and all new sensors. the problem is when it warms up the idle goes very low and high and sometimes stalls. i figure it would be something with the 02 sensor witch is brand new so when i unpluged it and it ran fine so i went out and bought a new one and the same. i herd something that i need 3 wire plug or adapter. any help? thanks alot for everything you guys are great help.
Old Feb 24, 2010 | 02:09 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Re: 91 camaro idling high and low
Double check vacuum lines. Is the chip you used a custom burnt chip exact to your mods? If it is just a "plug and play" chip, it may not be suitable, especially with a non stock cam.
Old Feb 24, 2010 | 02:36 PM
anthonyrs's Avatar
its a hypertech chip. i have all new vacuum lines and i triple checked them all. the engine runs fine when the 02 sensor is unpluged. when its pluged in its very loopy up and down and stalls.
Old Feb 24, 2010 | 02:51 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
A daying fuel pump can also cause unstable idle. Low fuel pressure would confirm.
Old Feb 24, 2010 | 03:07 PM
anthonyrs's Avatar
i check my fuel pressure while the car was running it was around 12. i did not noticed the pressure moving it stayed the same the whole time.
theshackle
Sep 17, 2020 08:26 AM
jklein337
Sep 19, 2018 06:23 PM
Fronzizzle
Aug 19, 2015 01:36 PM
perZ
Aug 15, 2015 01:17 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
