Will I need a different chip
Old Apr 2, 2010 | 07:38 PM
marcos beltran's Avatar
I did the swap from a 305 tbi to a 350 tbi and plan on getting another intake and boring it out. Along with that I plan on grinding down the ridges off the throttle body and a throttle body spacer. Can I get by with the stock chip or will need to do some tuning or a need to get a chip made?
Old Apr 2, 2010 | 08:30 PM
DSGx's Avatar
Car: 92 Pontiac Firebird
Engine: 305 TBI L03
Axle/Gears: 2.73 one wheel drive
Re: Will I need a different chip
I think u need a 350 chip, did u just swap blocks ? and left everything else from the 305 ? Like ecm chip injectors etc ? Cuz i think u need some things like a 350 ecm , chip , knock sencor , injectors and a higher psi fuel pump. If all u need is a chip then yeah u need a chip from a 350 car , like a caprice cop car or burn ur own chip or have urs made by a place like tbichips.com
Old Apr 2, 2010 | 09:29 PM
I have the 350 chip in it already. I was just wondering if by doing the intake and throttle body modification, will I need to get a performance chip or could I get by with the stock chip. I have an extra 350 tbi intake and an extra 305 throttle body so I can switch it back stock if I wanted to. Just curious if I were to do this cause I do not have the funds for a performance or modified chip right now. Please any info will be very helpful cause I plan on starting tomorrow while the weather permits.
Old Apr 3, 2010 | 04:13 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Originally Posted by DSGx
...injectors and a higher psi fuel pump. ...
305 and 350 TBI, FP (Fuel Pressure) are the same, around 11-13 psi. The fuel pump is the same too.
Originally Posted by marcos beltran
...I have an extra 350 tbi intake and an extra 305 throttle body...
The 305 and 350 TB are the same, intake is mostly the same to except some little exterior details.
The stock tune will support the ultimate TB mod. TB and ported intake easy.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
