Stupid question......TPS adjustment
Old Apr 27, 2010 | 07:48 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Ok guys, I need to know how to adjust my TPS on my 89 LO3....Are some just not adjustable??? Can't see any way to do it... If not, what do I need to buy...Mine is off a bit on the meter, and my off idle is not what I think it should be.My friend claims the one on his truck is adjustable..(also TBI)..Please help me on this question...Thanks, Tom
Old Apr 27, 2010 | 09:29 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Stupid question......TPS adjustment
Not adjustable. If it's not working right replacement is only option. IDK how much variation is acceptable though. No idea whether or not that's your problem
Old Apr 28, 2010 | 12:47 PM
Ronny's Avatar
Some are some not adjustable. ECU sets to zero% throttle in calc with engine off ign on. I presume that is to account for wear and/or if someone moved the throttle stop screw which I have done periodically to set idle with IAC control of idle disallowed.
Old Apr 28, 2010 | 01:14 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Sorry, didn't mean to add incomplete or misleading info. I meant that the one on your car which is the same as mine, unless someone has swapped throttle bodies, is the non adjustable type.
Old Apr 29, 2010 | 07:27 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Thank you very much for the info...We are going to try to use one off a truck, if possible.........
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
