Knock sensor location 89 LO3
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
In removing my exhaust manifold, I broke a sensor on the passenger side of the motor...Is that the fan switch, if so where is the knock sensor located on an 89 LO3??? I know on the drivers side is the temp sending unit....Thanks, Tom
Car: check
Engine: check
Transmission: check
Re: Knock sensor location 89 LO3
If what you broke is in the cylinder between 6 & 8, that is the fan switch.
Knock sensor is further down, right above the pan rail in front of the starter.
RBob.
RBob.
Car: 89 RS, 92 Z28
Thank you very much..Yes it was the fan switch....This job has turned out to be a nightmare..My whole car is in pieces the only thing left in is the motor....Hotchkis subframe connectors are the worst fitting thing I have ever seen, wish I would have gotten something else...Tom
86CamaroDan
Sep 29, 2015 10:08 PM
