Injector help on 89 iroc LO3
Old Jun 27, 2010 | 09:53 PM
AnotherWS6guy's Avatar
Car: 1987 Pontiac Trans Am STOLEN
Engine: 5.0L 4BBL Holley 650cfm Carb
Transmission: Stock 5-speed
Axle/Gears: Stock gears
89 camaro iroc z with the TBI LO3
It will start with starting fluid and once it starts you can press the throttle between nothing and WOT quickly and it will barely stay running. Looking at the injectors, they only spray every time you crack the throttle back open (or so it seems) but if you try to hold steady with the throttle or let off all together, it dies. I read the other thread about the injectors not pulsing so I have a few things I can try when I go back to the car again but in the mean time, please throw some ideas my way. And i took a volt meter to the injectors and with the key in ON position BOTH sides of each injector are showing 12v.
-Russ
Old Jun 27, 2010 | 10:23 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
Re: Injector help on 89 iroc LO3
Sounds crazy, but same symptoms occur with a bad coolant temp sensor. Located next to your thermostat housing.
Old Jun 28, 2010 | 10:47 PM
That would make the injectors not fire unless its already running and only when your feather the throttle???
Old Jun 30, 2010 | 10:26 PM
Haha I think you were right. I found today that the A/C compressor wires and coolant temp wires were touching. After pulling them apart and wiggling the injector wires it started and ran. Thanks dctrumpet!
Jae992
Aug 27, 2015 09:07 AM
tmellott89
Aug 16, 2015 02:58 PM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
