gt45 in stock LO3
Old Jun 27, 2010 | 12:39 AM
bduffey723's Avatar
Car: not a camaro anymore
gt45 in stock LO3
ive been looking at turbos alot lately and just had a few questions.. speed daddy has a complete gt45 kit but obviously requires more fuel to the motor.. im just wondering if a can just get bigger injecters or do i have to replace the fuel pump.. or both? also, any concerns or other parts i may want to change/install along with the turbo? thanks, Brandon
Old Jun 28, 2010 | 05:08 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: gt45 in stock LO3
A turbo setup requires more than just new injectors. You need new injectors, intake manifold, turbo headers, induction system, tuning, new fuel pump, tuning, etc. Theres a lot involved with going with a turbo. youd probably be better of just staying N/A with TBI. You can still make a lot of power w/o the turbo. With a turbo, an L03 would still probably be slower than a built 350.
Old Jun 28, 2010 | 02:39 PM
bduffey723's Avatar
i already have all that.. and i kno i needed more fuel.. just wondered if i could get the right amount without changing the fuel pump..
Old Jun 28, 2010 | 11:32 PM
bduffey723's Avatar
so would i be ok with getting an 80gph fuel pumpwith 24lbs/hr injectors? and where would be a good place to buy one? im leaning towards an external..
Old Jun 29, 2010 | 12:11 AM
89_RS's Avatar
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
The stock TBI injectors are 55pph injectors IIRC. You'd need a 255lph in tank pump, alot of work on the TBI, and the EBL from Dynamic EFL to get that turbo setup properly.
Old Jun 29, 2010 | 03:06 PM
bduffey723's Avatar
80gph is 302lph.. so i shuld be good there..
and i can keep my ecm with the ebl if i read correctly?
and one more.. wat all do u mean by work on the tbi? new throttle body?
Old Jun 29, 2010 | 03:19 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
EBL needs to be installed in the ecm, a vacuum referenced fuel pressure regulator is a must, you also need a 2 or 3 bar map sensor not sure anymore wich one of the 2.
There is probably all the information you need here http://dynamicefi.com/
Since you are goin forced induction, the stock TB should be ok.
Old Jun 30, 2010 | 12:28 AM
bduffey723's Avatar
everybody on here says to get the dynamic ebl so i will for sure be getting that..
wuld it be easier/better to do a carb swap?
Old Jun 30, 2010 | 12:38 AM
bduffey723's Avatar
doesnt it have a maf not a map sensor?
Old Jun 30, 2010 | 01:37 AM
Car: 88 Camaro SC
Engine: SFI'd 350
RBobs EBL still uses MAP.
Old Jun 30, 2010 | 02:30 AM
thomas1976's Avatar
Car: 91 Trans am
I doubt carb will be better, basicaly EBL, 2 or 3 bar MAP sensor, VAFPR, dctrumpet's 30psi FPR spring and a highflow fuel pump, should be all turbo-TBI specific parts you need for now.
EBL has every features needed to tune and control forced induction.
Boost release valve, TBI/carb bonnet+ducting+filter, turbo headers/manifold, coustom y pipe/exhaust, WB 02 sensor, ... are not TBI related.
Old Jun 30, 2010 | 12:19 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
If your new to tuning your own engine? Yes....
Old Jul 2, 2010 | 12:35 AM
bduffey723's Avatar
the local mechanic sed tht the tpi fuel pump wuld work?
Jeremys87
Jul 14, 2022 09:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Genopsyde
Oct 7, 2015 08:35 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
