Low 13s
Old Jul 5, 2010 | 07:17 PM
prettyboyced's Avatar
Car: monte carlo ss
Engine: 5.7
Transmission: th350
Low 13s
i have a 350 with 193 stock heads and comp magnum 270 cams edelbrock intake and carb shorty headers and 3.73 with 9.3:1 compression
Old Jul 6, 2010 | 12:15 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Re: Low 13s
Good for you but whats that got to do with the price of tea in China?
Old Jul 6, 2010 | 08:09 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: Low 13s
low 14's
Old Jul 6, 2010 | 02:06 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
Re: Low 13s
You're probably going to need better heads to get to your goal.
Old Jul 6, 2010 | 02:12 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Low 13s
I'm gonna post since I would also like to be in 13's.
Old Jul 8, 2010 | 01:45 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Low 13s
Not at all....
Old Jul 8, 2010 | 03:06 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: Low 13s
You might make it. Best thing to do would be to try it out.
Old Jul 8, 2010 | 03:13 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Re: Low 13s
Since fast corrected me I'll add to this. You could get there with some work, but it would be easier to use other heads. If your car is light enough and with some porting you could get there, but it will be a challenge. Thats kinda like putting a big cam in a stock L03 to get to low 14's. Possible, but not easy to accomplish.
Old Jul 8, 2010 | 09:21 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Low 13s
My brothers 1980 C10 truck with a 305 is in the 14s with STOCK swirl port 350 heads on my old 312 shortblock. Crane 272H10 cam, Stock 810 swirl ports with spring upgrade, 1.6:1 full roller rockers, and long tube headers. Performer RPM Q-Jet and a tweaked Q-Jet.....TH-350 with a 2,600 stall and 3.42 gears. 28.5" tall tires on it. Ran a 9.39 @ 74 in the 1/8 in 100*F heat.
Old Jul 9, 2010 | 09:31 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Low 13s
To echo what Fast said the heads aren't the issue. Refer to the head flow data sticky at the top of the forum. 193 heads and 187 heads (305 version) are capable of supporting more power than people think. It all comes down to the tune, often leading people to beleive that the heads are the weak link. Tuning is everything.
Falcon50
Aug 22, 2020 03:26 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
