air cleaner/hood clearance
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: air cleaner/hood clearance
yeah I think so. Most guys are running a 14X3 do a search. Drop base may not clear unless you use the stock gold ring thing. If that's the case you might just get a flat base cleaner. Again do a search.
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
I searched and got confused, I guess the part I overlooked was dropped base and flat base differences. Thanks
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
I found the same air cleaner with "centered base" would that be the same as flat i kinda feel dumb asking this lol
http://www.jegs.com/i/JEGS/555/50002...oductId=751908
Engine: gone
Transmission: gone
Axle/Gears: gone
ok I did a little search and from what I have seen. 14x3 with a 1/2 inch spacer drop base mostly clears. some have said a raised base with 14x2 air cleaner. Id take the bigger air cleaner myself. Dont hold me to any of this I have not done that and I have more room to work with (cowl hood). Good luck.
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
I found a 1/2 spacer for 6 bucks which means I can get the dropped base to fit. Would it be easier to get the centered base 14x3 to fit without the spacer? Having a cowl hood must be nice for clearance issues never wanted one till now
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
Well this cleared it all up for me
https://www.thirdgen.org/forums/tbi/76046-attn-rich92rs350-question-concerning.html
Thanks for the help undercover
-I get page not found when I click link but if u copy and paste it pulls up-
Engine: gone
Transmission: gone
Axle/Gears: gone
you welcome for the help. that's what the board is here for. Just help the next guy if you can and we will keep it all rolling.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
If you use the drop base be sure to wrap the coil wires with plastic wire loom all the way to the coil. You may even want to use electrical tape on the bottom side of the base plate were the coil sets and even around the coil wires and wire loom.. Any thing to keep the coil wires from directly touching the bottom of the metal base plate just as a extra precaution.
New2Chevy
Sep 28, 2015 12:35 AM
