5.0 injection
5.0 injection
i have a 91 camaro that is not injecting.. i installed new pump, relay and injectors.. it was running good after the new injectors.. i turned it off, went back 15 min later and the injectors are not working now.. what could have happened?
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: 5.0 injection
Are you getting spark? A common problem is the ICM (ignition control module) it has been known to kill spark, injector pulse. just one, or sometimes both.
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
Re: 5.0 injection
You could try spraying starter fluid into the tbi while turning it over to rule out if its fuel or spark. If the car begins to start, its fuel related.
