89 firebird 305 TBI Build/Help?
Old Nov 7, 2010 | 02:30 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
Ok im starting my project, just went to Napa and bought tons of parts. Right now, i need to drop my fuel tank, so i can flush it out, and ensure theres no sludge in it, due to it sitting for about 2 years... Is anyone able to give me some info/help on how to drop the damn thing without rippin apart my exhaust?
Any advice will be appreciated, i know theres a few threads about the same thing, but i will also have more questions down the line, as i get closer to getting this thing street worthy.
Thanks,
-Matt
EDIT:Sorry for the crappy phone pics...
Old Nov 7, 2010 | 02:31 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
Re: 89 firebird 305 TBI Build/Help?
I have the driver side rear end jacked up with stands, trying to get the damn tank out...
Old Nov 7, 2010 | 05:12 PM
DSGx's Avatar
Car: 92 Pontiac Firebird
Engine: 305 TBI L03
Axle/Gears: 2.73 one wheel drive
Ur exhaust seems like its welded so u prolly dont have any other choice but cut the muffler off.
Old Nov 7, 2010 | 06:00 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
yup looks as though you will have to cut and re-weld when your done. last time I changed my muffler I went ahead and put a flange on the muffler to be able to unbolt it. (also good if I wanted to try different mufflers etc.)
Old Nov 7, 2010 | 07:55 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
Ive been an automotive technician for only about 3 years, but i still cant weld, and im a shotty metal cutter... should i just take it to a shop to get it done? what am i lookin at for a towing bill do you think?
Thanks guys
Old Nov 8, 2010 | 12:00 AM
DSGx's Avatar
Engine: 305 TBI L03
Thanks guys
It just pretty straigh forward lol, place wichever powered cutter ur using agains the pipe and press the trigger and hold it well u dont want those tools flying off your hands while being on.
Old Nov 8, 2010 | 07:54 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
Welding it back on is the problem... i can cut just fine, would anyone suggest cutting off the exhaust and then just getting one of those metal connectors with two clamps to put my exhaust back together?
oh and i went to NAPA to get an open element air cleaner, and the guy never even heard of one, they need to get people who actually know what there doing to work in a parts store... checked autozone and couldnt find one either... might have to order one online. any suggestions?
Old Nov 9, 2010 | 12:25 AM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
That should be fine. I plan to make mine to make it 100% removable.
As for the Open Element, My local Autozone had it in their ***** section. Its where they keep all the flashy things and other things like gaskets. I think they have just the Edelbrock version at mine. My local Oreillys had a Spectre Open Element that I liked, had the air filter top lid too, think it was $40. If they dont have it check out Summitracing.com or Jegs.com get one with a flat base to have good clearance and not rub on anything.
Old Nov 9, 2010 | 02:32 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
Its been sitting for almost 2 years, what shouold be my main concerns? im gonna change the oil, belts, spark plugs, motor mounts, coolant hoses, thermostat, thermostat housing, etc... my upper hose wont fit over my new housing, should i try n stretch it, use lube?
Old Nov 9, 2010 | 02:37 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
Its close, but no cigar...
Attached Thumbnails 89 firebird 305 TBI Build/Help?-coolant-hoses.jpg   89 firebird 305 TBI Build/Help?-therm-housing.jpg
Old Nov 9, 2010 | 03:07 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
I would think you should unbolt your catback at the cat and pull it out if you want to drop the tank. You will also need to unbolt some of the suspension and drop the rear down to drop the tank fully. I did this when I did my fuel pump. Speaking of that you should replace your fuel pump with a higher flow one while your in there.
Old Nov 10, 2010 | 01:34 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
that sounds like a pain in the ***, what suspension parts have to come off? someone said i had to drop my differential to get the tank out? i hope not, im working with limited jacks and stands, ive got 4 stands and 1 jack, i hope thats all i need
Old Nov 10, 2010 | 07:24 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
Instead of dropping the tank, i made an access panel to the fuel pump from inside. Il post up sdome pics in the morning, didnt have time to finish the job today.
Old Nov 14, 2010 | 08:43 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
Anyone change motor mounts themselves? I need some tips on how to do it?
Old Nov 14, 2010 | 08:58 PM
Jix01's Avatar
Car: 1990 Pontiac Firebird
Engine: 305 5.0 TBI
Axle/Gears: 2.73 Open Diff.
I just pulled the fuel filter off put a bucket underneath it and cranked it over. Each time you crank it(even for a second) the fuel pump comes on and spits out fuel for about 15-20 seconds. I did this until the tank was near empty.Got 3 gallons of water out of it. after new fuel and cranking for about 5 minutes it finally started. runs perfect now.I realize your trying to get sludge out so i'm not sure if this will help?
Old Nov 15, 2010 | 11:04 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
when i pulled the pump out, i saw no sludge and the gas was only about 6 months old. But now it cranks but DOESNT start. I replaced the spark plugs, fuel pump, oil, coolant, hoses, belt. Put injector cleaner in the gas, and it still doesnt start. Its really starting to **** me off! for some reason, the spark plugs they gave me are a little longer than the ones i had in it before. could that be the problem. i even tried spraying ether into the intake, and it will barely start to run and then dies. brand new battery too
PLEASE HELP!
Thanks everyone
**EDIT: I only cranked it for about 10-15 seconds, should i crank it for longer so the lines can fill with fuel? Im kinda new to all this, any help is appreciated**
Old Nov 16, 2010 | 08:27 AM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Try swapping your fuel pump relay. After I did my fuel pump I had the same problem after all that work. Turned out to be the relay too. You could even pull one of your other relays and put it in place to test. There should be 3 of them on the firewall under the hood. One on passenger side and two on drivers at least in my 91. I forget which was for the fuel pump.
Old Nov 16, 2010 | 05:08 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
heres a pic of the fuel pump
Attached Thumbnails 89 firebird 305 TBI Build/Help?-fuel-pump.jpg
Old Nov 17, 2010 | 05:14 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
Ok, I got it to start, but it seemed like the injectors were just pouring out fuel. Also I could hear a slight knocking sound during idle, and it was idling kinda funny too. What could be the problem now?!?
Old Nov 17, 2010 | 06:48 PM
Matt1821's Avatar
Car: 87 Trans Am
Engine: 350 carb'd
Axle/Gears: Stock
I guess it just needed to be ran for a little while, but the ol' bird is back on the road! Thanksbeveryone for your help. Next is off to paint and body...
Glowsock
Jul 24, 2025 03:15 PM
xkingcodex
Feb 12, 2020 07:43 PM
MENINBLK
Aug 5, 2015 11:58 PM
