88 firebird
Old Nov 18, 2010 | 12:09 PM
8732's Avatar
88 firebird
i recently picked up an 88 firebird with a 305 tbi and a 5 speed for 800. it doesnt start up. just cranks and spits anybody know what could be causing this? need some input cause idk what could be wrong
Old Nov 18, 2010 | 11:07 PM
DSGx's Avatar
Car: 92 Pontiac Firebird
Engine: 305 TBI L03
Axle/Gears: 2.73 one wheel drive
Re: 88 firebird
Remove ur airfilter and see how ur injectors are flowing while ur cranking if they hardly spit any fuel then u might have a bad fuel pump or bad fuel preassure regulator, also check for spark, and since its an old car and still has original spark plugs and cables u should atleast replace those first before buying anything expensive. This TBIs are pretty basic so u should start ur troubleshooting by checking spark and fuel. Also if u got both of those ok then u should play with the distributor if the thing moved and its offtime then that might be causing those spits wich i think are backfires. Thats my advice, but w8 until someone with more knowledge answers im just a regular guy that just knows how to do the easy stuff hehehe.
Oh btw before u do anything u should atleast remove one spark plug and see what condition there are in, bad sparkplugs can be your problem and nothing else more expensive, it prolly has the original spark plugs.
Old Nov 19, 2010 | 01:11 AM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Re: 88 firebird
see if it starts on starting fliud. but dont keep spraying it as you can bend a valve. good luck
64goatman
Sep 9, 2015 01:09 PM
jtwoods4
Sep 3, 2015 05:39 PM
Formula_88AE
Sep 3, 2015 01:47 PM
jtwoods4
Sep 3, 2015 10:19 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
