What does this connector go to?
Old Jan 3, 2011 | 07:31 PM
DeCaff2007's Avatar
Hey guys.
91 Firebird 5 speed TBI. Has a 92 Camaro 305 under the hood.
This connector wasn't connected to anything before the engine swap, so I don't even have a reference point.
Where the heck does it go?
Here's a closer shot. Sorry it's so blurry.
Any ideas?
Old Jan 3, 2011 | 07:46 PM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
Re: What does this connector go to?
It's to your IAT the sensor in the base of your air cleaner.
Old Jan 3, 2011 | 08:15 PM
DeCaff2007's Avatar
LoL well that could explain my SEL, and running rough (slightly rich).
However, how the hell to plug that thing in when this is my air cleaner?
Old Jan 3, 2011 | 08:19 PM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
I know what u mean when I pit my open elment in I drilled a hole for my sensor and plugged it in
Old Jan 3, 2011 | 08:38 PM
DeCaff2007's Avatar
Where? I can't really make it out from that pic. I'm guessing you took the bottom plate and just drilled a hold big enough for the sensor?
I'm really hoping that if I do this, the SEL shuts off and the engine runs right.
I have the timing set as exact to 0* as I can get it.
Not sure of fuel pressure, what it should be, or even how to set it.
Injectors seem ok (although I can smell fuel while running).
Meh, I'm just throwing ideas out there. Time to order an IAT sensor.
Old Jan 3, 2011 | 08:46 PM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Yea it's under I have my idle set at about 8 advance. Have you done a major tuneup as well as check all vacuum lines too
Old Jan 3, 2011 | 08:52 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
yeah you need to have it plugged in...deffinately better to have it mounted in the air cleaner
Old Jan 3, 2011 | 09:00 PM
DeCaff2007's Avatar
LOL well I'll take care of the timing later. Right now, I just want to get that sensor.
I'm seeing two different parts here:
Here's an Air Temperature Sensor for a 91 Firebird at RockAuto.com
Here's the same part on a random Google search:
http://www.discountbodyparts.com/cat...3913iase91pofi
Old Jan 3, 2011 | 10:15 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
neither one looks like the one on my 89 tbi camaro...could be different for that year though?
Old Jan 4, 2011 | 12:04 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
The one you posted from rockauto is the air temperature sensor that activates the thermac. Wich you do not have anyway with the open element air cleaner.
The other one you posted is for TPI, at least the one in the pic.
Here is a small practical one that works http://tpiparts.net/inc/sdetail/499 mine even included a sealing/mounting rubber ring. Pics of it https://www.thirdgen.org/forums/post...761-post2.html
Old Jan 5, 2011 | 07:35 PM
DeCaff2007's Avatar
Yep, that one in the link you posted is close. I went to Advance Auto and they had to order it. It came in tonight so I went an matched it up to the loose connector.
Perfect fit! So, then I drilled a hole in the bottom plate of the open element and voila! Then, I plugged the connector in and snapped off the gray retaining tab
Doesn't really matter as it's still pretty tight. I'll get another connector from the j/y if really necessary.
Otherwise, that's just one more thing off my "to-do" list for my Firebird.
Old Jan 6, 2011 | 04:04 AM
thomas1976's Avatar
Car: 91 Trans am
Yep, that one in the link you posted is close...
Close?
Old Jan 6, 2011 | 04:50 PM
DeCaff2007's Avatar
Close?
Yes, it's not the EXACT sensor. The one I have is a little shorter and has a plaster washer molded into it. The connector looks the same but the point is mine installed and working now.
Old Jan 6, 2011 | 08:36 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
It's a 'air charge sensor' cost like $20.
I had the same question about it in my car. It measures the air time to control Jim much fuel is pumped out
http://www.autozone.com/autozone/par...mString=search
Old Jan 6, 2011 | 10:48 PM
DeCaff2007's Avatar
Yep, that's the one...
Huh??
Old Jan 7, 2011 | 10:28 AM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
How much fuel is being pumped out.
I'm on a iPod doing all of this so it's hard to type.
Old Jan 7, 2011 | 06:47 PM
DeCaff2007's Avatar
No clue. How do I check that?
Old Jan 7, 2011 | 06:53 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
Sorry for not being clear. That sensor let's the injectors how much fuel to pump out.
Old Jan 8, 2011 | 07:04 AM
DeCaff2007's Avatar
So in the absence of that sensor, could the engine get really BAD fuel economy, and run extremely rich all the time?
That's what was happening. I haven't had a chance to take it for a test run yet but I might today
Old Jan 17, 2011 | 06:06 PM
Guest
Guest
Posts: n/a
Let's clean that engine bay make her look nice!!!
Old Jan 17, 2011 | 06:33 PM
DeCaff2007's Avatar
LoL if you're referring to me, this Firebird will likely be sold before I get a chance to pretty it up.
Old Jan 17, 2011 | 09:44 PM
Guest
Guest
Posts: n/a
Why are you selling it so fast you clean that up though you make a couple extra bucks.
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
