INJECTOR POD SPACER !!!
Old Jan 11, 2011 | 11:01 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
let me start by saying that i'm a cruiser not a racer . i have many mild mods on my car . my last one , today i installed an injector pod spacer on my TBI . now my TBI unit was pretty stained up from 20 yrs of use . anyway i followed the instructions to install to the letter . took great care to keep all things clean . cleaned the injector pod very well when i had it removed . cleaned everything on the TBI unit with it still on the car . CLEAN , clean & more clean . anyway started up , ran smooth & nice . i was happy , left my nephews shop for lunch . went to waffle house (i'm in the south), a couple of young men asked about my car . (it does look good) they asked me to get on it when i left . O.K. i did , i felt a seat of the pants response . much better , crisper throttle response , and faster speed . just my thoughts , JEGS , Summit , CFM all sell them . just what i felt , i expect a lot of nay sayers from this post , but i feel it worked for me . good luck to all .
Old Jan 11, 2011 | 11:43 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: INJECTOR POD SPACER !!!
I felt more when I did this mod but I also did a couple other mods at the same time with my air induction so it was hard to say how much it really did for me. For the cost. Not a bad mod. And not too hard to do.
Old Jan 12, 2011 | 12:50 AM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
I did this mod as well but cant really say if I could tell the difference. There is more room for air to flow in theory.
Old Jan 12, 2011 | 09:19 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
Yup the theory is right. I do think the other mods I did outweighed this mod
Old Jan 15, 2011 | 12:59 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
I just ordered one after reading this. The ad claims a 4 hp increase. What the hell, 4 hp is 4 hp. Several small increases in power add up.
Old Jan 16, 2011 | 12:55 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
I know especially for 19 dollars or whatever they are running now. You probably did not have to order one. I know plenty of people who just double stacked a gasket for the injector pod and basically got the same results.
Old Jan 17, 2011 | 09:20 PM
fernando rs's Avatar
Car: 1988 Camaro RS
Engine: 5.0 TBI
Axle/Gears: 4TH. GEN. REAR
I had thought the samething! but never went through with it..Im going to try it this time
Old Jan 18, 2011 | 07:18 PM
UNCLE TOM's Avatar
i am not selling anything , i just wonder how many gaskets it would take to to raise the pod 1/4" ? might take quite a few . how much are the gaskets ? i would guess from the thickness of the gasket i removed that it would take 20 or more . oh yes , also the cost of 3 new torx screws 1/4" longer ? just my thoughts , good luck .
Old Jan 18, 2011 | 10:22 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
The gaskets I have seen two double stacked are about the same distance.
Old Jan 18, 2011 | 10:50 PM
UNCLE TOM's Avatar
much different from the gaskets i have seen . where did you get them , and do you have a part # ? just curious , i hate to waste money . thanks .
Old Jan 18, 2011 | 11:07 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Gotcha I'll take a look tomorrow and see if thier is a part # on it.
Old Jan 19, 2011 | 07:41 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
The pod spacer usually includes the longer mounting screws too.
Does not really make any difference at all on stockish LO3's, but it is so easy and the theory sounds so good.
Also the spray pattern does not change drastically, so it can't hurt.
Old Jan 19, 2011 | 01:10 PM
EagleMark's Avatar
I thought I'd be really cool and do a double stack!! HA! Injectors sprayed outside the bore...
Old Jan 19, 2011 | 02:31 PM
thomas1976's Avatar
Car: 91 Trans am
I did that on 2 LO3's and did not have that issue.
Also on one running 24psi trough the #55 injectors, no issue.
Old Jan 19, 2011 | 04:15 PM
EagleMark's Avatar
Guess mine was bigger!
Old Jan 19, 2011 | 04:39 PM
92firebird 305's Avatar
Car: 1992 pontiac firebird
Engine: 305 v8 lo3 201.5hp and 268.2 tq
Transmission: 4speed 700r4 corvette servo
Axle/Gears: 3.42 disk posi 4th gen rear swap
hi i have a 92 firebird 305 tbi i wanna do this mod so where do i get he gasket and longer bolts is there a part number
Old Jan 19, 2011 | 05:03 PM
thomas1976's Avatar
Car: 91 Trans am
Maybe I missunderstood, did you mean you stacked two spacers?
Could try to search tbi spacer on ebay.
Old Jan 19, 2011 | 07:52 PM
UNCLE TOM's Avatar
if your injectors sprayed outside the bore i think you have a bad spray pattern . time to get injectors cleaned , good luck .
Old Jan 19, 2011 | 07:58 PM
UNCLE TOM's Avatar
check post #1 , jegs , summit , CFM all carry them . under TBI check injector pod spacer . good luck .
KCG
Jun 24, 2020 04:33 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
webeeZ28
Sep 14, 2015 12:00 PM
92rsvortec350
Sep 10, 2015 10:54 AM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
