TBI spacer question
Old Mar 18, 2011 | 05:23 PM
ultra91's Avatar
Car: 1991 Camaro RS
Engine: 5.0
Transmission: auto
TBI spacer question
Ive been told a throttle body spacer would give me more power out of my 91 RS with stock 305. they are not to spendy, around 50 bucks at Summit racing.com, but im just curious if anyone has installed one on their stock third gen and if they think it helped or not. Thanks
Old Mar 18, 2011 | 05:28 PM
Guest
Guest
Posts: n/a
Re: TBI spacer question
ive had one on a 350 and really didnt notice a difference myself. i would just save your $50 and time and troubles of putting it on. u have to do slight modification but its not hard to do i just never seen any real difference.
Old Mar 18, 2011 | 05:29 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
With those heads, there's really not much of anything that will help - save the cash for a 350 TBI or carb swap.
The only thing you'll really "feel" is getting rear gears - and they work for any motor. Don't spend cash on the 305 UNLESS it will later transfer to a 350 (like rear gears, exhaust, etc.).
Old Mar 18, 2011 | 05:52 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
yup dont wase you rtime or money on it. do an exhaust upgrade, headers-back. that and a nice rear gear swap will make ya happy.
Old Mar 18, 2011 | 07:03 PM
EagleMark's Avatar
There are some tech writeups on this website and I think they cover the TBI spacer and other TBI tricks, may want to read them first.
https://www.thirdgen.org/technical-articles then scroll down.
Old Mar 18, 2011 | 09:04 PM
ultra91's Avatar
Car: 1991 Camaro RS
Engine: 5.0
Transmission: auto
Thanks, kinda what i suspected. Looks like ill just leave it alone and be happy with my 17mpg and no power
Old Mar 18, 2011 | 09:42 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
your only getting 17 mpg? You have something wrong. You should be pulling at least 20. 23-28 is commonplace for these cars. Is she running good?
Old Mar 18, 2011 | 10:28 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i agree with all of the above . but , i did a little research they don't much , the entire TBI spacer that is . what does/has seemed to work for me is the " INJECTOR POD SPACER " . it raises the injectors 1/4-5/16" higher , i swear i felt a small improvment . my day to day mileage went up a bit , throttle response felt a bit more crisp . now i am a bit **** about keeping a good tune on my car . anyway i'm not looking for a debate , i am just telling my thoughts on what i have done . BTW no clearance problems with stock air filter . good luck , cheers .
Old Mar 21, 2011 | 09:39 PM
ultra91's Avatar
Car: 1991 Camaro RS
Engine: 5.0
Transmission: auto
im sure i could pull better mileage, my daily driver before the camaro was an 81 chevy pickup, 400hp 454, built th400, 4.56 posi. so i tend to push the 305 a little hard
Old Mar 21, 2011 | 10:08 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
ahhh that kind of makes sense then...drive her easy!
Old Mar 23, 2011 | 04:19 PM
d00012's Avatar
Car: 2006 GTO
Engine: LS2
Transmission: M6
Axle/Gears: 3.46 LSD
The TBI spacer is really only ideal for higher RPM power or frequent WOT. Not worth it with a stock 305 motor.
Old Mar 30, 2011 | 06:20 PM
Bram's Avatar
You should get better mileage. My 85 Pontiac wagon weighs 4800 lbs is carbureted and got 16.0mpg. My newer 93 Caprice wagon weighs 4600 lbs and gets 20.2mpg and I don't drive it easy. Its got load exhaust and the most pick-up I've driven since my 390GT mustang days.
Somewhere on the web some folks did dyno's on TBI spacers and basically you lose low end HP & torque and gain a couple of HP over 5000 RPM.
Old Mar 30, 2011 | 10:16 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Yeah and for an engine where cylinder heads doesnt flow well over 5000 rpms. its better to keep the low end torque.
MustangBeater20
Oct 29, 2022 09:20 PM
customblackbird
Aug 15, 2021 10:16 PM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
