350 TBI swap. HELP!
Old Mar 21, 2011 | 07:51 PM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
350 TBI swap. HELP!
hey guys, i just did a 305 to 350 TBI swap. i'm now using a ecm, esc and knock out of a 92 caprice w police pakg. My car is not idleing well and will not rev above 2500 rpm. I do have a manual tranny. I am also waiting for the right injectors to come from rockauto to come. Let me know what you guys think.
Old Mar 22, 2011 | 07:18 AM
EagleMark's Avatar
Re: 350 TBI swap. HELP!
If you have the ECM from the cop car and the injectors are from the cop car you should not need injectors...
As far as the other stuff do you get a check engine light? What are the codes?
Old Mar 23, 2011 | 06:08 AM
ex-x-fire's Avatar
Double check your firing order, make sure the tbi base gasket isn't leaking. Make sure theres no vacuum to the egr at idle.
Make sure you unplug the timing connector when setting the timing, it should advance when you rev it.
You may have low fuel pressure or if you have 305 injectors it might be running lean.
Old Mar 23, 2011 | 06:45 PM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
No check engine light. I ordered new injectors, still waiting for them to show up. I thought it would at least ide with 305 injectors. would the tps sensor be different, just wondering.
Old Apr 2, 2011 | 05:00 PM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
Ok I have put in the 350 injectors, set timing to 0. there is some vacuum at egr at idle. Engine still will not rev above 2500. No vacuum leaks to be found.
Old Apr 2, 2011 | 09:24 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
check your fuel pressure. check your firing order.
Old Apr 5, 2011 | 05:23 PM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
Ok double checked firing order it is right, fuel presure is good 12psi. I did notice that after I set timing to 0 and plugged the computer back in. the computer advanced the timing so much the noch on the balancer is almost on the pass side of engine. any thoughts?
Old Apr 7, 2011 | 11:32 AM
Ronny's Avatar
180 out?
Old Apr 8, 2011 | 06:06 PM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
Nope it's set right. Im kinda leaning towards a bad computer? it did come from a junk yard.
Old Apr 11, 2011 | 07:16 AM
HiPerf_Chevyman's Avatar
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
thats Normal for the Timing to Jump. 180 out it would pop through the intake. its not the TP sensor, they dont change Values for throttle % for diffrent CID motors. Bigblocks are the same as a 2.8 V6.
Ive had a egr Stick open before, Stick your Finger in it and see if its open. Both inj. are firing?
Old Apr 11, 2011 | 09:08 AM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
The stumbling/misfiring doesn't happen until 2500rpm regardless of the gear. Might hafta check the valvespring rate.....runs good then all hell breaks loose and engine falls on its face.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
Dwayne614
Sep 28, 2015 08:33 AM
CamaroGuy350
Aug 26, 2015 05:11 PM
Eric-86sc
Aug 24, 2015 09:01 PM
