cam advancing?
Old Mar 23, 2011 | 08:12 AM
kill4thril's Avatar
Car: 1990 firbird formula
Engine: 355ci
Transmission: t56 spec3+ cluch
Axle/Gears: 9 bolt disc brake 2.77
cam advancing?
ok so i was reading around and saw something about advancing my cam timing i was just wondering if some one could give me some more info on what it does and if its woth it ?
Old Mar 23, 2011 | 12:07 PM
EagleMark's Avatar
Re: cam advancing?
Advancing cam timing will give more top end power. Retarding will give more bottem end power. Doing either with out a degree wheel while building a motor can cause horrible engine damage...
Old Mar 23, 2011 | 03:47 PM
ex-x-fire's Avatar
Re: cam advancing?
Eaglemark has it back wards, adv. the cam boasts low end, retarding it helps top end.
You can get away w/ 4 degrees either way, unless you have a wild cam.
A a timing chain wears, it stretches, it retards the cam.
On a street motor, I'd go w/ a fresh timing set & advance it 2*.
Old Mar 23, 2011 | 05:20 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Re: cam advancing?
ya eaglemark was backwards. Advancing will drive the powerband down and vice versa.
It's not worth it for a stock cam
Old Mar 25, 2011 | 08:07 AM
EagleMark's Avatar
Re: cam advancing?
I guess age is showing again, dam I hate when I do that...
Old Mar 25, 2011 | 01:26 PM
xch3no2's Avatar
Transmission: TH400
Re: cam advancing?
ya otta seen some of the goofy stuff I've posted...
Old Mar 25, 2011 | 02:16 PM
EagleMark's Avatar
Re: cam advancing?
yeah but by the picture in your avatar your oltimers could be disaterous...
ChaseDale3and8
Sep 1, 2015 01:49 PM
masonta
Aug 31, 2015 10:14 PM
billybob6110
Aug 30, 2015 02:47 PM
lt1z350
Aug 28, 2015 05:57 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
