7.4 throttle shaft and butterflies
Old Mar 26, 2011 | 10:30 AM
noff1313's Avatar
I'm looking for replacement parts for throttle shaft and butterflies for the 50mm 7.4L throttle body. Does anyone have a lead, or is the only option to make them?
Does anyone know an way to flow test CFM on altered throttle bodies?
Old Mar 27, 2011 | 01:22 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: 7.4 throttle shaft and butterflies
Could try here
http://www.turbocity.com/default.php...39f0e107257ba5
http://www.cfm-tech.com/
http://stores.ebay.com/TBIPARTS?_trksid=p4340.l2563
Old Mar 27, 2011 | 03:23 PM
oldred95's Avatar
I don't mean to hijack but what about bushings for when the throttle shaft is all sloppy and is causing a vacuum leak? Put a TB spacer on mine today and just so happened to grab a hold of the throttle linkage and thought dang that is loose. Went for a drive and it would be a whistle tip to shame.
Old Mar 27, 2011 | 06:26 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
ATS - Zako tool, ZA-05
http://www.supercooltools.com/html/catalog.html
or maybe it's ZA-02, seems to be some confusion.
http://www.throttleshaftrepair.com/p...s/product2.htm
Old Mar 27, 2011 | 06:44 PM
oldred95's Avatar
That would work but that costs too much for just one throttle body.
Old Mar 27, 2011 | 07:21 PM
xch3no2's Avatar
Transmission: TH400
Just 4 you Red,
http://cgi.ebay.com/ebaymotors/ws/eB...d=230553699916
Old Mar 27, 2011 | 07:35 PM
oldred95's Avatar
You calling me a tight ***? Because you would be correct. I like the looks of that better. I keep forgetting a carb repair kit will work just as good too.
Has anyone actually had theirs apart? I'm wondering if those diamond coated insanely hard throttle blade screws are reusable or not.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
DiabloWS6
20
Dec 11, 2015 04:12 PM
DARKmj16
Sep 9, 2015 04:07 PM
Randomtask2
Sep 7, 2015 05:06 PM
dbrochard
Sep 7, 2015 09:41 AM
