smog delete belt
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
smog delete belt
Looking to remove smog pump, making a high whinning noise and some other noises. So i'm asking someone who has full removed it and what size belt did you get? This is a 89 camaro 305 tbi with serpentine setup.
thanks,
timinsk
thanks,
timinsk
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: smog delete belt
Tech article states a 6 rib, 96.8 inch belt. I found no one making belts except in 1/2inch increments. Think I ended up using a 95.5 inch - you'll just need to but a 95, 95.5, 96, 96.5, 97 take them all home, use the best one, return the othjers (saves 15 trips to the store).
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Car: 1988 GTA Black on Black Hardtop
Engine: 383 miniram/ Ebl
Transmission: 700r4/Performabuilt/3000 Stall
Axle/Gears: 9 bolt / 3.27
When i deleted mine,I used the same belt. You just have to route it differntly. There is several posts about it on here with a drawing of the routing. This was for a tpi serpitine setup if that matters.
Car: 1992 RS
Engine: Carbed 350
Using the same belt can only be done if you use a delete pulley - which isn't needed, but without the delete pulley you need a different size belt.
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Not true. I pulled off my pump and used the same belt. The belt is routed differnt than from factory. Not sure if it works for your tbi but it works for my tpi serpentine. search on tgo for the belt routing diagram. I have it but dont know how to post it on here. I was going to do the same as you and buy a differnt belt until i found the new routing.
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Upon further review and researching i stand corrected. Although i didnt have to change belt sizes when i deleted my pump, others probably will. A longer belt had already been installed on my car allowing me to reuse my belt after pump removal. Sorry for the confusion.
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Yes, the 96.8" Im sure you could use other sizes. Just has to be long enough. I personally am using a 98.0" and it works fine.
Car: 1992 RS
Engine: Carbed 350
That's why I suggested buying several sizes and using the best and returning the rest - everyone's car is different, and everyone used a slightly different size.
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Engine: gone
Transmission: gone
Axle/Gears: gone
just like the article says. a little longer belt with stock pullies.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
From the viewpoint of an amateur engineer, I would say the life of those alternator's bearings are in jeopardy with that belt rounting.
doesnt seem too different than the factory routing when it comes to the alternator. factory routing is tensioner-alternator-power steering.
Engine: gone
Transmission: gone
Axle/Gears: gone
it covers 75 percent of the pulley. its still turning the same direction. you think thier is too much tension on it?
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
It doesent matter how much of the pulley the belt raps around. Because these cars have a automatic tensioner with a spring in it. That is what controls the side load on the bearing, the only thing your changing is the general direction the side load is pushing.
The only other way you could effect the load on the bearings is to use a shorter belt witch would make the spring in the tensioner get compressed tighter.
