not getting Fuel. Fuel pump?
Old Mar 28, 2011 | 02:47 PM
weswisehart's Avatar
Car: 91 RS T-top
Axle/Gears: 3:42 fourth gen disk brake
I have put a 305 tbi into a car that I believe the previous own had carbed. Iam not getting any fuel after the install. I pulled back the carpet and found this.
I see a grey, a purple, and a black wire. Where do these wires go? Id like to track them down and be sure they are connected properly thanks.
Old Mar 28, 2011 | 03:15 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: not getting Fuel. Fuel pump?
black is the ground.
grey ran to the original intank electric fuel pump to power it, from the original oil pressure sending unit that was located above the oil filter.
purple is the sender wire to the gas gauge.
Old Mar 28, 2011 | 04:20 PM
Car: 91 RS T-top
Awesome so just ground the black and make sure the grey is getting power while the key is on? The unit above the oil filter was recently broke off when I was dropping the motor in. Should I replace this immediately?
Old Mar 28, 2011 | 07:11 PM
Car: 91 RS T-top
I put a hot wire from the battery to the red wire shown in the picture above. I heard the pump come on. Shouldn't I be able to start the car while its hot? I'm not get fuel out.
Old Mar 28, 2011 | 08:12 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
No but, the same unit also has the sender for the gauge built into it.
The fuel pump is controlled by the FP relay (which is controlled by the ECM). The oil pressure switch is a redundant power source (or, fail-safe if you so like to call it) for the FP and can be thrown in the trash.
Old Mar 28, 2011 | 09:23 PM
Car: 91 RS T-top
OK thanks ill get a new one this week. I hope to track down the wires to the fuel pump. I see the go up near the fuse box but after that I'm not sure.
Old Mar 29, 2011 | 10:33 PM
Car: 91 RS T-top
Looks like a stock fuel pump. The wires have all been cut but I will fix them and reinstall all this and hope it works.
Old Mar 30, 2011 | 11:40 AM
Car: 1992 RS
Engine: Carbed 350
Since you have it out, I'd replace the fuel pump NOW. That might be the original pump, and no telling how long it will last - you are already here, might as well replace with a good new pump and save yourself dropping the tank again next year.
Old Mar 30, 2011 | 04:36 PM
Car: 91 RS T-top
If it still pumps ill keep it. My luck ill get a faulty new one. Its not bad dropping the rear took 2 hours if that. Besides money just got really tight. My woman just moved out yesterday so bills are all mine.
Old Mar 30, 2011 | 05:07 PM
Car: 1992 RS
Engine: Carbed 350
They are trouble, better off without them ... I know, I'm on my second marriage!
Get an extra friendly female room mate, save your love for your car!
Old Mar 30, 2011 | 06:15 PM
Car: 91 RS T-top
Ha ha yea I'm starting to think so. I've always wanted kids but times like these I'm glad I don't.
Old Mar 30, 2011 | 07:24 PM
Car: 1992 RS
Engine: Carbed 350
Rent the neighbors kids for a week - you'll soon change your mind!
I know about rug rats too ... I have 5 boys ...
1 is mine from my 1st marriage
2 are my wife's from her 1st marriage
2 are from my wife's 1st husband, from HIS prior marriage
They are now 16, 17, 18, 22, 24 - the youngest being mine own.
Kids are like dogs ... they are cute as hell when they are puppies, when they get older you just want to take them to the pound
I'm being silly, ignore me. I really think everyone should personally endure the hardship of kids and wives at least once in their life!
Old Mar 30, 2011 | 07:54 PM
Car: 91 RS T-top
Ha ha wow 5 boys. Well for the time being it will just be me the two dogs ( 5 month old pit bull),(2 month old great Dane, lab mix) and my two camaros.
Old Mar 31, 2011 | 02:39 PM
Car: 91 RS T-top
ok i need wiring schematics. I am not getting hot to the grey wire. I followed it all the way near the fuse box. i believe it goes into the fire wall. after that im lost
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
