Injector pod problems
Old Apr 17, 2011 | 08:48 PM
J-money's Avatar
Car: 92 RS camaro, 99 Z-24 cavalier
Engine: 5.0L TBI, 2.4L
I just added the injector spacer mod under my injector pod and I have badly cross threaded one of the threads in the pod that the nuts go in. I havent had a chance to try a thread chaser to rethread them but its in pretty bad shape. My question is if I have to get a new pod, will the pod off from any 3rd gen TBI engine work for my 92 TBI?
Old Apr 17, 2011 | 08:58 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: Injector pod problems
THE NUTS???? screws hold the injector pod down. do you mean one of the fuel line adaptors??
Old Apr 17, 2011 | 09:12 PM
J-money's Avatar
yes the part that connects from the back of the pod to the fuel lines.
Old Apr 17, 2011 | 09:19 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
ok so did you strip the theads where the fuel line's screw in? or where those fuel fittings screw into the pod? if its the latter, it'd be easiest to go to the junkyard and get another one...you could try rethreading it...
Old Apr 17, 2011 | 09:27 PM
J-money's Avatar
where the fittings screw into the pod. Any idea how much one of those would cost at a junk yard? I seen a few on ebay for around 40$
Old Apr 17, 2011 | 09:32 PM
one92rs's Avatar
Car: SOLD!!!!!
get another one. fuel is not the fluid to be leaking on a hot engine.,
Old Apr 17, 2011 | 09:35 PM
J-money's Avatar
ok I figured I would have to get another one. Ok one last quick question, when I swap my injectors into a new pod should I go ahead and get new O-rings to go with it?
Old Apr 17, 2011 | 11:04 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
it woudlnt hurt too!
Old Apr 17, 2011 | 11:17 PM
J-money's Avatar
Ok Im assuming all the injector pods for the different years TBI engines are the same then. Alright guys thanks for the help I really appreciate it.
Old Apr 17, 2011 | 11:27 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
basically. you'll find one pretty easily
Old Apr 18, 2011 | 11:45 AM
EagleMark's Avatar
As far as the hundred or so I have worked on they are all the same except for an industrail 366 big block.
Frozer!!!
Jan 19, 2024 04:55 PM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
arod231
Aug 16, 2015 02:51 PM
89lsc
Aug 14, 2015 04:58 PM
