high idle issues
Old May 19, 2011 | 12:11 AM
Birdstheword's Avatar
Car: 1988 Pontiac trans am
high idle issues
well i finally got her running right except my idle is to high , http://youtu.be/bQb2Qo1K-KE
Old May 20, 2011 | 06:09 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Re: high idle issues
Did you replace your throttle positioning sensor? Did you clean, or replace your IAC?
Old May 20, 2011 | 11:18 PM
I rebuilt. My tbi. Unit so yeah I sprayed down the iac with. Break. Cleaner
U. Bv
Old May 21, 2011 | 02:11 AM
U. Bv
could just be a vac leak
Old May 21, 2011 | 02:44 AM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
my iroc does too. new iac, maf, o2 sensors, msd cap+rotor 8.5m wires fresh plugs. no vacc leaks. in gear it idles normally though. idle is around 16-1800
Old May 21, 2011 | 03:09 AM
dano2377629's Avatar
Car: 1986 IROC Z Z28
Engine: 355
Transmission: TH 350 3200 rpm stall
Axle/Gears: 3.73 posi
Something is wrong there it shouldnt idle that high. You gotta figure that out.
Old May 21, 2011 | 06:07 AM
EagleMark's Avatar
U. Bv
If you let brake cleaner run downhill into the IAC motor it can get in there and ruin the electrics. When you use brake cleaner etc... you need to do them motor side up.
Unless you used a smake machine you could still have a vaccum leak under the intake, in valley pan. Now that I think about it if it's a TPI that maight not be true... check brake booster, check PVC valve, check EGR valve? HTH!
Old May 23, 2011 | 12:25 PM
all my vaccum hoses are new , pcv is new , egr gasket is new , this thing idles at 2k rpm right from the start and it wont go down unless i put it in drive , after that as soon as i let off the brake pedal it just takes off fast
Old May 24, 2011 | 11:40 AM
silentkillzr's Avatar
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
Same issue here. I think its my TPS cause when i unplug it i have no change in idle or drive ability
Old May 24, 2011 | 12:10 PM
Going to try adjusting the minimum idle speed as explained. In the tech article
specialized
Jun 18, 2022 09:26 AM
bamaboy0323
Sep 3, 2015 06:07 AM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
