TPS interchange
Old Jun 7, 2011 | 01:32 PM
SinthetikIroc's Avatar
Car: Corvette
Engine: 5.7
TPS interchange
I am piecing together a system from JY parts. I got a wire harness and all the hard parts. However the connector on my harness and the connector on my throttle position sensor are different.
So my question is, do both type of sensor read same voltage etc? Can I swap the connector or the tps to match the other without problem? If I can swap the tps to match the harness I would prefer to do it that way.
My harness has the connector like this
and my tps sensor on the tbi is more like a pyramid configuration.
Which is the preferred method?
Old Jun 8, 2011 | 10:04 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: TPS interchange
Over the years GM fielded three different TPS sensors configuration (used with TBI-220) which provide same voltage back to ECM - about 0.4 to 0.9 at idle position and about 4.3 to 4.7 at WOT position. Just make sure that have ground and +5 volt lines correctly connected.
The pyramid configuration TPS is a later style sensor and has a slot that engages throttle shaft. The earlier TPS used a lever that rested on the cam face of the throttle shaft. You can not mix TPS - it has to to match throttle shaft.
I hope this makes sense.
//RF
Old Jun 8, 2011 | 07:46 PM
Car: Corvette
Engine: 5.7
Re: TPS interchange
So I have to get a new connector for the TPS. Easy enough. Thank you.
Old Jun 10, 2011 | 04:04 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
Re: TPS interchange
Let me know if you need anything!
Sean
Old Jun 10, 2011 | 09:04 PM
Car: Corvette
Engine: 5.7
Re: TPS interchange
I have everything together now. Just need to swap the connector to get the TPS hooked up and see how it runs.
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
sbrandon
Sep 9, 2015 07:31 AM
