Start then stall
Old Jun 11, 2011 | 07:13 AM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Start then stall
My 91 TBI Firebird starts then stalls sometimes but after I try it a few times it works fine. Anyone have any idea?
It stalls almost like I was just turning the key off. Some times after I start it I give it more gas and it will bog then stall.
Old Jun 11, 2011 | 07:26 AM
insomniac's Avatar
Engine: 5.7 L98
Re: Start then stall
map sensor voltage KOEO at idle is about 1.5 is that low?
Old Jun 11, 2011 | 01:48 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
possible fuel pump problem. fuel leaking back into tank or something of that nature. check the cold psi of fuel pressure if its within specs 9-13 psi then using the gauge see if it bleeds off quickly. also try "priming" the fuel system. by this I mean turning the key on but not cranking over the car. then turn the key off. then back on again letting it sit for a few seconds, then off letting it sit for a few seconds. try this 3-4 times and see if it starts better.
jklein337
Sep 19, 2018 06:23 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
Bryan F
Aug 18, 2015 02:28 PM
