TBI to TPI with stock wiring harness...
Car: TransAM
Engine: 355SBC
Transmission: TH700R4
I´ve got an idea.. :-) I want to go from TBI to TPI, but i don´t want to change the wiring harness. If i change the stock intake manifold to a speed density TPI intake manifold and i go from 2 100´injectors (80´@19 PSI) to 8 25´injectors. Does it work ? Are there direct fit systems on the market ?
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: TBI to TPI with stock wiring harness...
I dont think you can do that. The math and division/multiplication work. But the ecm fires the injectors different. You may have to remove certain parts of the harness and add in TPI parts etc....and to do all the work, you might as well change the whole harness. That's my
db057
Aug 11, 2015 10:11 PM
