Where should this tube be?
Old Jul 12, 2011 | 06:36 PM
SMKNTRS's Avatar
Hey Guys,
I noticed a hose was laying in my engine bay. I assume it should be attached to my Charcoal Canister. This would be great cause I haven't been able to get my car to pass Ohio echeck. I noticed the one part of the canister looks like a hose could slip into it but it has this plastic clip on it that forces the hose to a 90 degree. Any help?
Old Jul 12, 2011 | 07:15 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: Where should this tube be?
IIRC it goes to the large port on the bottom of the TBI unit, not the PCV port but the other one ..... id look but all my emissions are gone
Old Jul 12, 2011 | 07:49 PM
SMKNTRS's Avatar
I see that port with no line on it says AIR on the canister. Should this loose vacuum line I found hookup to it?
Old Jul 12, 2011 | 07:57 PM
one92rs's Avatar
Car: SOLD!!!!!
the line from the tank goes to the bottom fitting of the solenoid which is also the line that comes from the valve inline near the canister. the top line from the solenoid goes to the far left vacuum port on a tbi. the one fitting in the pic goes to fresh air or nothing.
Old Jul 12, 2011 | 08:23 PM
one92rs's Avatar
Car: SOLD!!!!!
that looks like it might be the vacuum tube that goes to the ball underneath where the charcoal canister goes.
Old Jul 12, 2011 | 08:30 PM
SMKNTRS's Avatar
Thanks for the hose diagram. I followed the line to under the TBI and the hose that goes to the fuel. I still have this rouge vaccum line that I dont know where it goes. I traces the rouge line back to this sucker by the EGR valve. Still not sure what that is or where it should go.
Old Jul 12, 2011 | 09:08 PM
SMKNTRS's Avatar
i did some searching and found that it's supposed to go to a vacuum reserve canister. but i dont know where that is.
Old Jul 12, 2011 | 09:10 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
tucked up in the wheel well on drivers side.
Old Jul 12, 2011 | 09:37 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Just behind the turn signal lamp and under the battery/evap canister tray.
Old Jul 12, 2011 | 09:46 PM
SMKNTRS's Avatar
Your the man! Was a bitch getting the broke vacuum line off but glad that problem is finally solved. Hope it will help me pass echeck lol
gixxer92
May 18, 2017 11:20 AM
no green
Jan 9, 2016 09:22 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
FormulasOnly
Oct 2, 2015 05:52 PM
zman1969
Oct 1, 2015 11:09 AM
