#191 Heads??
Old Jul 25, 2011 | 01:07 AM
ChevyK0051's Avatar
Car: 1995 Chevy K1500 extended cab white
Engine: 5.7L TBI V8
Transmission: 4l60E
Axle/Gears: stock (3.73?)
#191 Heads??
I was looking around a lot for heads to put on my truck and found that the used engine I bought to rebuild came with 193 swirl port heads. Then it got me thinking what heads were on my truck since I bought my truck from an awful backyard mechnic that said he doesn't know how the engine was, he just dropped it in since the original 350 burnt 6 quarts of oil in driving 2 hours So he called the other engine good enough without even knowing anything about it. So I was extra curious since my left hand head on my truck is painted blue while the other side is rusty like the block.... so I checked the blue one since its easier to take the valve cover off and it's a 191 head. Just wondering what the benefits to the 191s are or cons over regular 193 heads? I heard the 191s are just hardened 193s? It makes me wonder if the rusty right hand head is another 191 or not..but it runs better since I timed it correctly now and put AC Delco plugs in it...before it was badly out of time and i don't remember how many spark plugs didn't work....
I've researched the 191 heads on the web already a little but didn't really come away with anything other than they're like 193 heads, after that the forums erupt in how bad the 193 heads are and I don't find my answer Lol I have a 4x4 K1500 so the swirl ports are OK...and cheap with good fuel economy! Just wondering if anyone had specs on them.
Thanks!
Jordan
Old Jul 25, 2011 | 12:31 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Re: #191 Heads??
AFAIK the 191's and 193's are nearly identical /direct replacements.
Old Jul 26, 2011 | 03:34 AM
ChevyK0051's Avatar
Engine: 5.7L TBI V8
Transmission: 4l60E
Re: #191 Heads??
so they're close. but why would GM use a new casting number if they didn't make any changes?
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
