car wont start
Old Aug 1, 2011 | 06:13 PM
psmith757's Avatar
Car: 91 Camaro RS
Engine: 5.7 350 TBI
Transmission: t56
Axle/Gears: 4.10
car wont start
hey i have a 91 rs with a 90 burb 350 in it. the car always starts up and rives fine but today i tried to start it and absolutly nothin happened. no clicking no cranking or anythin. only thing that happened is when i try to start it like my radio and interior light and stuff turn off untill i let off the start position.
Old Aug 1, 2011 | 07:34 PM
BillyTheGoat's Avatar
Car: 1989 Trans am
Re: car wont start
It sounds like a dead battery. Do a quick test with a volt meter, it should be over 12v (12.6 if its good).
Old Aug 1, 2011 | 07:39 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: car wont start
When you turn the key to start, does the security light come on and stay on?
Old Aug 1, 2011 | 09:02 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: car wont start
bad battery connection or bad battery it seems.
Old Aug 1, 2011 | 10:34 PM
psmith757's Avatar
Car: 91 Camaro RS
Engine: 5.7 350 TBI
Transmission: t56
Axle/Gears: 4.10
Re: car wont start
ok ill check the battery and then security lights but would a bad starter or starter connection be a reason for this to happen?
Old Aug 1, 2011 | 10:35 PM
psmith757's Avatar
Car: 91 Camaro RS
Engine: 5.7 350 TBI
Transmission: t56
Axle/Gears: 4.10
Re: car wont start
and also all my interior lights work and radio and all the stuff that comes on when key is in ignition
Old Aug 1, 2011 | 10:40 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: car wont start
it could be a bad starter. take a hammer and smack it once on the side and see if it unsticks it. if after your battery tests come back okay.
Old Aug 1, 2011 | 10:43 PM
psmith757's Avatar
Car: 91 Camaro RS
Engine: 5.7 350 TBI
Transmission: t56
Axle/Gears: 4.10
Re: car wont start
i had a friend jump it and it didnt help at all. so im pretty sure my batterys good
Old Aug 1, 2011 | 10:50 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: car wont start
did you leave the cables on there for a few minutes before you tried starting? if its really low a jump will not always start it right away.
Old Aug 2, 2011 | 09:32 AM
psmith757's Avatar
Car: 91 Camaro RS
Engine: 5.7 350 TBI
Transmission: t56
Axle/Gears: 4.10
Re: car wont start
no but ill try. the battery is less than 6 months old and so is the alternator so dont think its the battery
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
