312 tbi?
Old Aug 4, 2011 | 08:13 PM
kill4thril's Avatar
Car: 1990 firbird formula
Engine: 355ci
Transmission: t56 spec3+ cluch
Axle/Gears: 9 bolt disc brake 2.77
312 tbi?
ok so i have a stock 305 tbi and my friend is selling a 312 that was originaly a 305 tbi that he swiched to carb the motor is all redone and makes about 300hp on the dyno im looking at geting the motor and putting the tbi back on it with the ebl flash and i was just wondering if the stock tbi system like the fuel pump and everything would work with the motor and if not what i would need to make it work.
Old Aug 4, 2011 | 09:11 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: 312 tbi?
bigger fuel pump. being bored out isnt much really. if the heads have not been changed its really not worth it. but you need a fuel pump upgrade regardless.
going thru all that work, might as well go a 350 TBI.
Old Aug 4, 2011 | 09:27 PM
kill4thril's Avatar
Engine: 355ci
Re: 312 tbi?
the 312 is already built and its only 600$ but yeah there vortec heads and a high lift cam the motor was compleatly rebuilt and makes 300hp on the dyno with a 600carb
Old Aug 4, 2011 | 09:28 PM
kill4thril's Avatar
Engine: 355ci
Re: 312 tbi?
if i got the stock tpi fuel pump would that work?
Old Aug 5, 2011 | 04:28 AM
the solitaire's Avatar
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
Re: 312 tbi?
The stock L98 fuel delivery might work. You need about 19 PSI of pressure, so a higher rated fuel pressure regulator needs to be used as well. The stock one goes up to somewhere between 12 and 15 PSI.
I'd advise to pick up something like a Walbro 190 lp/h or 255 lp/h instead.
Still, provided you fit all that and the stock TBI setup, you might see slightly less power then the carb setup, because of the difference in intake manifolds.
I guess it'll be hard to fit an Edelbrock RPM with TBI plate under the stock formula hood, but maybe the Edelbrock TBI intake could be used.
Old Aug 5, 2011 | 07:17 AM
kill4thril's Avatar
Engine: 355ci
Re: 312 tbi?
i was just going to get a weiand carb intake with egr and put a tbi adapter on it
Old Aug 5, 2011 | 09:26 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 312 tbi?
Yes, that will work. At the lower fuel pressures they flow a lot more fuel. In this regard do not get a 255 l/ph pump. It will overwhelm the stock FPR and return line.
If going with a TPI pump be sure to get an AC Delco pump.
RBob.
Old Aug 5, 2011 | 10:03 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: 312 tbi?
Yes, listen to Bob, and be sure to pickup an AC Delco fuel pump. Do not let any auto store try to sell you on an AirTex fuel pump, as they'll try to tell you that AirTex took over production. They are garbage, and they are unbelievably loud, believe me. Stick with an AC Delco pump....
http://www.summitracing.com/parts/ACF-EP241/
Old Aug 5, 2011 | 10:22 AM
Ronny's Avatar
Re: 312 tbi?
Consider a low profile Weiand Accelerator(single plane) with adapter plate for clearance?
May want to opt for 7.4L TB at that time. Aeromotive FPR has 5-20 and 20-60 springs.
top down solutions sells a spring that goes 12-18 or so.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
