Switch TBI to Carb? More or less power?
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Switch TBI to Carb? More or less power?
pretty much the same. your still restricted by pisspoor cylinder heads, a small camshaft, and a cruddy exhaust system. But one thing you'll deffinately gain is higher gas bills.
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Done right, the GM TBI can support all the HP your likely to make.
I sure wouldn't swap TBI for a carb at your power level.
JMHO
JMHO
i went from tbi to carb. once tuned correctly it ran great on the freeway and around town. but kept having to tune it. getting the timing just right and the carb just right was a biatch. but i did have a little more power on the freeway but not much. i then went back to tbi. stock gm intake. ultimate tbi mods and a custom tbichips chip. the driveability again on tbi is awsome. man did i miss it. now with the tune i dont think i gained nothing but headaches.
a properly tuned well modded tbi will beat a carb on a stock engine anyday. and i spent a lot of time and money on the carb set up. now that i have my properly tuned and modded tbi system i will never go back again no matter what people say. trust me i have had both.
now
dont do it.
now
dont do it.
prolly forgot to mention i have no egr(tuned out) and no cat. also shortie headers (hooker and ypipe ) and a 3" magnaflow catback.
Engine: gone
Transmission: gone
Axle/Gears: gone
yes exhaust upgrades, header, high flow cat, and cat back exhaust is highly recomended as one of the first mods
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
The very marginal (if any) performance gains you might get from a carb do not justify the expense at all on a fairly stock motor. You need an intake ($200+), carb ($250+), distributor ($125+), TCC lockup kit ($100+), return-style fuel pressure regulator ($100+),TV cable corrector ($20), and at least another $100 in misc to put it all together.
So, you're looking at almost $1000 (new parts prices) to swap, and you'll never really notice anything performance wise, but you will notice an empty wallet from feeding the carb gas (mpg cut in half).
Now - keep in mind this is coming from a guy that did swap to carb! But, I swapped from TBI to carb, and also swapped from 305 to 350, all at the same time, and all for the same $1000 (I bought a used, ready to drop 350 carbed motor for $650) - included was the carb, intake, distributor ... a complete motor. Now that was worth it!
The advise of the day - don't spend any money on the 305 on anything that cannot later be swapped to a 350 (ie silly to get a 500cfm carb now when your 350 would be happier with a 600-700cfm carb).
Spend your money on exhaust, suspension, brakes, rear gears, etc. (stuff that a 350 will also use) until the day comes when you can swap out that 305 (if hp is what your looking for).
And of course I say 350 - but you might have your sights set on a LSx swap etc. - same difference - spend money now that will "swap" to your future powerplant plans.
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
Car: 1983 G20 Chevy
Transmission: 4L60
Anybody else notice that newby pulls up a post that is nearly 1 year old to talk smack about how great his imaginary car is.
I have two crew cab/quad cab trucks that would probably wipe the floor with his camaro.
86IROC112
Aug 17, 2015 02:00 PM
