thermostat question
Old Aug 13, 2011 | 11:17 AM
bigreed91's Avatar
Car: 1990 camaro rs
Engine: 5.0L 305 tbi
thermostat question
Hey guys i did some searching and couldnt really find any good answers on here. I bought a 180 degree thermostat for my car, i dont like that it runs normal around 220, i havent put it in yet. I was wondering if anyone else has done this and if they had any problems afterwards like running rich, etc.
Old Aug 13, 2011 | 11:26 AM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: thermostat question
i got a 160 with no problems
Old Aug 13, 2011 | 12:13 PM
bigreed91's Avatar
Car: 1990 camaro rs
Well if your good with a 160 i should be fine with the 180, any reason you went with a 160 over 180?
Old Aug 13, 2011 | 12:22 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
160 will richen up the mixture. When i put a 180 in my mileage got better.
Old Aug 13, 2011 | 12:23 PM
ninetyone's Avatar
Axle/Gears: 3:42
Your fan should come on about 15 degrees after your thermostat rating , for example a 160 thermostat, the fan should come on at 176. The chip should be modified for this change.
Old Aug 13, 2011 | 12:57 PM
bigreed91's Avatar
Car: 1990 camaro rs
do they make a fan thermostat switch that comes on at a lower temp to replace the stock one?
Old Aug 13, 2011 | 01:58 PM
ninetyone's Avatar
Axle/Gears: 3:42
you can try the hypertech one, on at 176/ off at 166 or if you have a 180 thermo use the on at 200/off at 185 switch.
Old Aug 14, 2011 | 01:25 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
yeah change the switch. a 180 is fine. 160 is too low. keeps the car in open loop burning up uneccesary gasoline
Old Aug 14, 2011 | 08:57 AM
ninetyone's Avatar
Axle/Gears: 3:42
I agree. My mileage even went up when i switched to a 180 stat.
Old Aug 14, 2011 | 12:39 PM
bigreed91's Avatar
Car: 1990 camaro rs
well im gettin 19mpg in city drivin with the stock t-stat, i might try and put it in today, if not next weekend.
Old Aug 15, 2011 | 12:08 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
180 is what Ive been running for the last 5 years. Seems to be the perfect middle ground for me. Not to cold and not to hot. Just right.
Old Aug 15, 2011 | 01:05 AM
WilliamSilver's Avatar
i run a 195 at the moment but will also move to a 180 soon. In this northern CA heat (90-100*) the highest i hit was 203 in traffic on the freeway.
Old Aug 17, 2011 | 08:37 AM
Schurkey's Avatar
The thermostat controls the MINIMUM operating temperature, it does NOT control the maximum temperature.
If you're changing the thermostat because the operating temperature is more than 15 degrees above the thermostat rating...and the thermostat is not actually defective...you're changing the WRONG THING.
Old Aug 17, 2011 | 12:28 PM
Ninety-One's Avatar
Car: 91 LT1 RS 89 IROC-Z 350 TPI
Engine: LT1 // 350 TPI
Transmission: WC T5 // 700R4
Axle/Gears: BW 9 Bolt 3.27 //BW 9 Bolt 2.77
I would highly recommend getting a 180* thermostat and more importantly a 185* on/170* off thermal fan switch.(this is the big plug on the passenger side engine under the exhaust with one wire going to it. WARNING: it plugs the cooling system, so expect fluid to come out. During the summer about 105* in cali i can drive aggressively and it will stay around 180 all day...maybe creeps to 190 if i'm going up a steep grade for a long period of time.
Old Aug 17, 2011 | 01:51 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
So tell him what he needs to do to fix the problem
Old Aug 17, 2011 | 03:48 PM
DiabolicalRS's Avatar
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
BE CAREFUL with the bolts you are going to take out..i had to change my intake cause i broke a bolt and decided to drill it out and then use i screw extrcter which broke too.. you live and you learn.haha
Old Aug 17, 2011 | 03:58 PM
Schurkey's Avatar
The "problem" is that you aren't used to newer engines running that hot. There's a REALLY GOOD CHANCE that it's completely normal. With electric fans, the running temperature may be more than 15 degrees above the thermostat rating until the fans bring the temp back down. (depends on what temperature rating the fan thermostat is; or how the ECM is programmed.) It would be worth your trouble to ensure that the fan(s) work properly and engage at the temperature the engineers have set. Nothing like defective temp senders or burnt-out fan motors to create overheating problems--and that isn't fixed by installing a lower-temperature thermostat.
If everything else including coolant level and the radiator pressure cap checks out OK, and if you insist on "fixing" what isn't broken, your best bet is to change the temperature that the fan(s) engage. If that doesn't get you what you want, you'll need to install the 180 thermostat, and lower the fan engagement temperature again.
Old Aug 17, 2011 | 05:53 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
he wants it to run cooler so your advice is what we already said
italiano67
Dec 11, 2016 09:21 AM
krisner89
Oct 10, 2015 06:03 AM
Ducati900ss
Sep 2, 2015 09:05 AM
redmaroz
Aug 16, 2015 11:40 PM
perZ
Aug 15, 2015 01:17 PM
