Having problems, need some help
Old Aug 14, 2011 | 02:26 PM
fsbigcountry's Avatar
Hi guys, I've bought a 92 rs 305 tbi 5 spd. I'm having the same idle problem I see quite a few have. Also car will start to die at redlites sometimes. I smell fuel sometimes also. I have been reading on here and am in the process of checking iac, tps, temp sensor. I pulled the breather off and disconnected the temp sensor to read ohms. Car would not start. I hooked sensor back up and started car with breather off. I could hear something making a sound like a little motor running, it was loud sittin in the car. When I got around the front I saw that the sound was coming from the 2 injectors. I have never worked on a injected car. Should the injectors be loud? I tapped them with a wrench, no change. One of them is spraying quite a bit at idle, the other not as much. Is this normal for idle. Any help is appreciated.
Old Aug 14, 2011 | 02:50 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Having problems, need some help
You probably actually have a bad injector, its leaking down spraying too much. causing an overfueling problem, which will in effect kill the engine out randomly, and you'd have an excessive fuel smell. now IT COULD be something else. But the injector is deffintely a possibility
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
