Too little fuel?
Old Aug 24, 2011 | 06:50 PM
Rich92 RS's Avatar
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
Too little fuel?
The car's a 92 RS 305 TBI. Went to the store, came out and the car wouldnt start. Took the filter off to watch the injectors, and it seemed like it came out in drips, no spray. Hows the pattern suppose to look on start up?
The car cranks fine, but wont fire. The car has a msd box, and blaster coil so next will be that I guess.
Old Aug 24, 2011 | 06:59 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Too little fuel?
no gas? did you check spark? it seems like im always recomending it but I think you got a bad ignition control module. it depends if the injectors are spraying a little or not at all. if they are spraying some then more than likely your having a gas problem. ie. bad fuel pump, relay, etc..
Old Aug 24, 2011 | 08:13 PM
Rich92 RS's Avatar
Transmission: T56's
I looked at the injectors again, to see if it'd start and I saw no fuel coming out. Didn't even hear the fuel pump prime. So I guess its time to check the relay out.
Old Aug 25, 2011 | 06:21 AM
ex-x-fire's Avatar
If you have someone to start the car you can try banging on the tank, the fuel pump might start working.
Old Aug 25, 2011 | 09:15 AM
Rich92 RS's Avatar
Transmission: T56's
It runs... but it doesn't want to idle.
I replaced the fuel pump relay, well the relay on the firewall, furthest towards the drivers side. Fuel pump primed, and it started up after a couple cranks.
Any ideas on why it wont idle now? It idled fine for the first min or so. Then the rpms started falling, then back to idle, then falling, then back to idle, and so on till it wanted to cutout. I had the air filter off, and the iat sensor (or whatever its called) disconnect so I reset the battery, and plugged it back in, but that didn't help.
UPDATE: Went back to check some things, now the car wont start again. Fuel pump isnt priming again. WTF
Old Aug 25, 2011 | 10:30 AM
Rich92 RS's Avatar
Transmission: T56's
Fuel pumps not priming agian wtf.
Old Aug 25, 2011 | 10:45 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
Maybe a bad connection on the fuel pump relay connector? or maybe just coincidence and your fuel pump is actually bad
Old Aug 25, 2011 | 11:19 AM
Rich92 RS's Avatar
Transmission: T56's
Connection seems fine. One of the prongs on the old relay was burnt, so the connector has some discoloring from it. I doubt thats affecting it though. I was about to check the fuel pressure to see if the fuel pump was going out, but I guess thats not going to happen.
If I jump terminal A to E on the fuel pump relay the fuel pump should prime correct? If it doesn't time to replace the fuel pump? Could the ignition module, be bad?
Old Aug 25, 2011 | 11:29 AM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
A dying pump's excessive electrical load may have caused the relay damage.
The module controls both spark & injector firing, on separate circuits.
Old Aug 25, 2011 | 04:24 PM
Rich92 RS's Avatar
Transmission: T56's
It looks like I replaced the fan relay instead of the fuel pump relay. Either way both have new relays now. After letting the car sit for a few hours the fuel pump primed . So Ive got the fuel pressure tester hooked up and will try to start it in a couple hours, on the off chance it'll prime.
Any recommendations on a fuel pump or where to buy one? The owner will never be modifying the car.
Old Aug 25, 2011 | 05:36 PM
one92rs's Avatar
Car: SOLD!!!!!
there should be a red wire with a connector coming off the fuel pump relay that doesnt go to anything. this is the fuel pump test connector. put power to it and the pump will run until you disconnect it. also you could soak a rag in gasoline and put it above the tbi and see if it will idle.
Old Aug 25, 2011 | 06:52 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Most people run Walbro pumps and even though you say he is never going to modify it. I'd still put at least the WALBRO 190 LPH fuel pump in there. The stock pump is barely adequote for a stock engine.
Old Aug 27, 2011 | 02:12 PM
Rich92 RS's Avatar
Transmission: T56's
We pulled the pump to find this:
Looks like we'll need a new fuel pump harness connector, but what about the harness/connector from the top of the tank to the body? Where can we get one? Or will that one be fine?
Old Aug 28, 2011 | 07:23 PM
Rich92 RS's Avatar
Transmission: T56's
A big thanks to everyone who replied; UnderCover89TBI, ex-x-fire, xch3no2, one92rs. Thank you for the help, and replies. Also a thanks goes out to Pocket.
The car is up and running.
Old Aug 28, 2011 | 11:25 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Im glad you got her going well.
Old Aug 29, 2011 | 12:36 AM
one92rs's Avatar
Car: SOLD!!!!!
cool now go drive the hell out of it.
Old Aug 29, 2011 | 12:39 AM
eastmanboomer's Avatar
Based on the fact that you don't hear your Electric fuel pump, Check fuses, relays,But I'll bet its your fuel pump.. If so, Rockauto has great prices on Pump&strainer...
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
