Need help! 89 TBI
Old Jul 11, 2011 | 09:16 PM
Delo93's Avatar
Car: 89 Camaro RS
Engine: 5.0L TBI
Need help! 89 TBI
I have an 89 camaro with a tbi. I swapped a rebuilt engine in and now i'm making the final connections but I am having trouble remembering some of the connections and was hoping you guys could help me out.
First thing, I feel like i'm missing something. I dont know where the plug on the left side of my distributor goes. There is a similar plug that I also dont know where it goes; it is the gray one that is in the picture.
Also where does the coil wire on my dizzy cap go.
I feel like I'm missing something.
Old Jul 11, 2011 | 11:52 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Need help! 89 TBI
your missing your coil. both of those connectors go the coil. and the coil plug wire off of the distributor goes to the coil tower. You need a coil
Old Jul 12, 2011 | 09:16 AM
Delo93's Avatar
Car: 89 Camaro RS
Engine: 5.0L TBI
I thought so... where is the coil mounted on my car, on the firewall or on the intake... now i gotta figure out where in the heck i put it... not good
Old Jul 12, 2011 | 10:31 AM
SanAntonio3's Avatar
Car: 1988 Camaro Iroc-Z
Engine: 1994-1995 LT1 5.7
the coil on my 89 tbi is located and should be located between the distributer and the carb. mounted by two bolts onto the intake. one of those connections goes on the coil first, then the other snaps into the slot next to it...in sequence. Then the spark plug wire goes from that coil to the center of the distributor plug.
Old Jul 12, 2011 | 10:55 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
yup you'll see the two holes, one hole is shared with the throttle/tv cable bracket mounting hole. it'll be easy. just find the coil
Old Jul 12, 2011 | 01:37 PM
Delo93's Avatar
Car: 89 Camaro RS
Engine: 5.0L TBI
Haha, yeah finding it is the problem, might be another thing I gotta buy. Thanks for the help guys.
Old Jul 12, 2011 | 02:41 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
you buy a new one your not going to get new mounting brackets
Old Jul 13, 2011 | 09:38 PM
Delo93's Avatar
Car: 89 Camaro RS
Engine: 5.0L TBI
junkyard buy, or i know a couple people that have tbi trucks that are junk and i'll be able to get one of theirs... thanks again guys
Old Jul 13, 2011 | 09:51 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
That's good. Pittsburgh, PA? or Pittsburgh, CA?
Old Aug 5, 2011 | 05:37 PM
Delo93's Avatar
Car: 89 Camaro RS
Engine: 5.0L TBI
im in pittsburgh pa... hey guys, i got another question/problem for you. Got my coil and hooked everything up. I went to crank the engine for the first time and oil was squirting from this thing in the picture... does anyone know what it is and how i fix this problem?
Old Aug 7, 2011 | 02:27 PM
Napster134's Avatar
Car: 1991 Pontiac Firebird
Engine: 355 TBI
Transmission: 7004R
Axle/Gears: 3.27/42 ?
Whatever it is, I would take it out and stick a small plug in it. Had the same problem with a 82 el camino. Just bought a small plug with same threads and covered it up. Might be due to a different intake, ect.
Old Aug 8, 2011 | 12:25 PM
dualdj1's Avatar
Car: 98 Chevy Cavalier
that's an oil pressure feed for an oil pressure gauge or sending unit. if you're not using a mechanical gauge, just plug it off. Or replace it with an electronic sending unit so you can have an oil pressure gauge.
Old Aug 8, 2011 | 12:38 PM
Delo93's Avatar
Car: 89 Camaro RS
Engine: 5.0L TBI
Thanks, got it plugged, i just picked up some fresh gas and im gonna try starting it tonight
Old Aug 8, 2011 | 08:57 PM
Delo93's Avatar
Car: 89 Camaro RS
Engine: 5.0L TBI
i didnt get a chance to start it tonight, but quick question... is there some sort of blow off valve on the passenger side of the throttle body... because when I was trying to start it a couple days ago it was almost like it was igniting from that side or blowing off air in the line or something.
Old Aug 9, 2011 | 11:57 AM
dualdj1's Avatar
no you should not hear any air noises if everything is hooked up properly. Check and make sure all your vacuum lines are properly connected, spark plugs tight, etc. You should also have PCV valve connected and crankcase properly vented.
Old Aug 10, 2011 | 09:02 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
There is no 'blow off valve' in TB - you are probably hearing IAC trying to reset itself
//RF
Old Aug 15, 2011 | 08:15 PM
Delo93's Avatar
Car: 89 Camaro RS
Engine: 5.0L TBI
I filled it up with fresh gas, set it at TDC, and fired her up, sounds awesome, now i just gotta finish up exhaust and other stuff and i'll be good to go
Old Aug 18, 2011 | 08:53 PM
Delo93's Avatar
Car: 89 Camaro RS
Engine: 5.0L TBI
The noise i was talking about was backfiring in the throttlebody, not sure if it was old fuel or bad timing causing the issue, but i got it started... now i just need some help with what I can plug up and which vacuum lines go where... I'm in the homestretch guys... just a little more help that I would greatly appreciate.
Old Aug 18, 2011 | 09:26 PM
Delo93's Avatar
Car: 89 Camaro RS
Engine: 5.0L TBI
These are pics of the front of the throttle body. I dont know what I can plug up and what i need to run lines to. I read a post on here that showed you everything you could plug up, but i cant find it.
Old Aug 18, 2011 | 09:28 PM
Delo93's Avatar
Car: 89 Camaro RS
Engine: 5.0L TBI
This line was coming from the passenger side of the engine compartment, not sure where it goes but it is pretty long.
Old Aug 18, 2011 | 09:29 PM
Delo93's Avatar
Car: 89 Camaro RS
Engine: 5.0L TBI
Not sure what this is or what I have to do with it? It is next to the distributor.
Old Aug 18, 2011 | 09:32 PM
Delo93's Avatar
Car: 89 Camaro RS
Engine: 5.0L TBI
Also where does the line go to from the egr valve?
Thanks guys for all of your help in advance, this has been a long build for me and I've learned a lot along the way. I will be sure to upload a video to youtube when I get the finishing touches done.
Old Aug 24, 2011 | 11:10 PM
ignore this. havent figured out how to delete a screw up.
Old Aug 24, 2011 | 11:21 PM
That should be connected to a hose leading to the passenger side firewall(approximatley right behind the passenger side valve cover). It runs down to I honestly dont know where. But usually these hoses break right behind the valve cover. This, from what i was told controls the defog inside your car. Hope this helps.
Old Aug 25, 2011 | 08:32 AM
dualdj1's Avatar
EGR valve on my truck motor, goes to an EGR solenoid mounted on the intake manifold near the EGR. There's a vacuum line that goes to the input on the solenoid, and the output side goes to the EGR.
Old Aug 29, 2011 | 03:45 PM
I needed some help figuring out what some of these hoses and wires are suppose to lead to on my 89 305 tbi. The top photo is because the rpm gauge is always just topped out. How do I fix this issue? The center picture is of the front driverside behind the headlights... There are various hoses that I dont know exactly what they're suppose to lead to. Maybe you guys can help. And the bottom picture is of a few wires. Do i need these?
Old Aug 29, 2011 | 03:49 PM
dualdj1's Avatar
not sure about all of it, but the red arrow line should be vacuum feed to your cruise control unit. it should be direct to vacuum i believe. the other hose sitting on your canister purge, not sure what that goes to.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
