Heater Bypass Valve?
Old Sep 2, 2011 | 03:41 PM
Sparkko's Avatar
Car: 1988 Firebird Formula
Engine: 5.0L 305 TBI
I've been told by multiple people that my disconnected vacuum line is leading to my heater bypass valve, but as it appears, the bypass valve has been replaced with the object in the following pictures. I'm 90% sure that is where my missing bypass valve should be, but I'd like some reassurance. Also when I do buy a new bypass valve I need to know which hoses go where, considering my car has some makeshift plastic object in place of the valve. So yeah...
Attached Thumbnails Heater Bypass Valve?-img_0044-medium-.jpg   Heater Bypass Valve?-img_0043-medium-.jpg
Old Sep 2, 2011 | 06:38 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Heater Bypass Valve?
When you get the valve, the curved hose on the right in the pic goes to the single fitting on the side. The hose in the middle in the pic that goes to the heater core goes on the bottom of the two fittings on the back, and the hose on the left going to the return tube on the frame rail goes on the top of the two fittings on the back. Vacuum hose natch to the small fitting. Have fun!
Old Sep 2, 2011 | 07:15 PM
torque_is_good's Avatar
yup, i'm the guy who pointed you there
Now I'm also the guy who is going to tell you to redo the wire splices and why in the heck is the CTS spliced ?
What is going on under the hood of that stock engine?
Old Sep 12, 2011 | 05:06 PM
retro-roco's Avatar
Originally Posted by torque_is_good
...and why in the heck is the CTS spliced?
My guess... an aftermarket CTS (Coolant Temperature Sensor) with a different type of connector than stock, requiring the installation of the pigtail (also supplied by the aftermarket vendor).
allows them to offer it for more models, than only offering one with the correct connection.
Old Sep 13, 2011 | 05:35 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
I thought you had that fixed already. https://www.thirdgen.org/forums/tbi/...cuum-hose.html
Part # http://www.rockauto.com/catalog/moreinfo.php?pk=84473
Bubbajones_ya
Jul 6, 2024 08:32 PM
bbsr72
Sep 27, 2015 05:55 AM
sahlomonic
Sep 20, 2015 07:15 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
