L05 engine swap wats the recommended vortec items
Old Sep 22, 2011 | 09:20 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Got l05 swap in. 89 rs looking to be in 350- 400hp range what are recommended can heads intake etc to use on my setup thanks
Old Sep 23, 2011 | 05:22 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: L05 engine swap wats the recommended vortec items
For 350fwhp, http://www.summitracing.com/parts/SUM-162108/ or similar, edelbrock TBI performer intake or similar and comp cam 8-500-8 or similar, should be decent.
With Trick flow 195 heads, roller cam around 220-230 duration with around .520 lift and single plane intake, should get around 400-450fwhp.
To get a better idea, could download camquest6 and get a dyno symulator, wery helpful.
Old Sep 23, 2011 | 10:35 AM
Engine: 305 to 350
Axle/Gears: 10 Bolt
what about these heads casting 14096217 tpi 5.7 around 1988 centerbolt with 1.94 intake would these work
Old Sep 23, 2011 | 11:30 AM
Engine: 305 to 350
Axle/Gears: 10 Bolt
there 64 cc
Old Sep 23, 2011 | 02:03 PM
thomas1976's Avatar
Car: 91 Trans am
Did you try the search function?
https://www.thirdgen.org/forums/tpi/...hat-heads.html
https://www.thirdgen.org/forums/tags/14096217.html
The L98 heads (TPI) end with 083, according to the post on TGO the 217 heads you have should be better, thogh will probably require some serious work to make 350-400 hp
Old Sep 23, 2011 | 02:27 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
yea i did search didnt find any good stuff i know they will fit my block im just going to port and polish intake and exhuast and gasket match and throw in a cam and intake and put rollers in in future... im looking to be around 260 with the rebuild im doing now with out cam.. hopefully only the dyno can tell the truth
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
matthew911
Aug 12, 2015 09:38 AM
