Timing Questions...
Old Sep 27, 2011 | 01:06 AM
1Broke_camaro's Avatar
Car: 1992 Chevy Camaro
Engine: 350 TBi in the working
Transmission: 700R4 :(
Timing Questions...
Do these TBis get their adjustments like old school SBC where you gotta turn it for the degrees. or does the computer adjust the timing?? mine isnt vaccuum advance or anyhting, just an ign module and the rotor lol. just wondering if i can set the timing like i do with old school SB/BBcs or not
Old Sep 27, 2011 | 04:11 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: Timing Questions...
Yes, timing light and turn the distributer, just remember to unplug the EST connector before https://www.thirdgen.org/forums/sear...archid=4384402
Old Sep 27, 2011 | 07:10 AM
ok thankyou...... bad link though
Old Sep 27, 2011 | 03:02 PM
thomas1976's Avatar
Car: 91 Trans am
Sorry, the page with the search results does not work in the link.
Can type, "location EST connector" in the search feature, in case you are not familiar with it.
Old Sep 27, 2011 | 04:23 PM
yeup ill check it out when i get there. i just today got the motor to spin over on the key
Old Sep 27, 2011 | 04:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Distributor position sets the base timing, advance is controlled by the ECM.
Old Sep 29, 2011 | 01:39 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
This is from the technical articles section. You should go look around in there, lots of good stuff
https://www.thirdgen.org/settingtiming
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
