305 tbi to 350 tbi chip install??
Old Oct 16, 2011 | 05:05 PM
92FBirdVert's Avatar
Car: 1992 Pontiac Firebird Convertible
Engine: 5.0 TBI
Ive already read the sticky and I didn't read anything about if I can install the 350 tbi chip in my 305 tbi ECM. Do I have to buy an ecm?
Old Oct 16, 2011 | 05:14 PM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Re: 305 tbi to 350 tbi chip install??
as long as its a 746? ECM i believe you'll be fine. Me i did the same but i have a 88, im the unlucky guy that has a diff ecm than most other f-bodys, so i went with EBL flash, im actually waiting for my stuff to get here
if you are getting a chip over the internet i would look deeper into my options... i myself had bad luck with buying a chip from sme over the internet website and it made my car run worse than stock. If you are planning on performance i would check else were
Old Oct 16, 2011 | 05:35 PM
one92rs's Avatar
Car: SOLD!!!!!
wont it run a little richer on fuel.
Old Oct 16, 2011 | 06:49 PM
i figured he was speaking 305 tbi to 350tbi swapped and he needed a new chip. if you still have a 305 in car do not get a 350 chip what so ever.
Old Oct 16, 2011 | 07:37 PM
Engine: 5.0 TBI
correct i currently have a 305 tbi and now i want to swap to a 350 tbi.
Old Oct 16, 2011 | 07:51 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
you can run a 350 chip in the 305 computer that is all that is needed. if your runnign a 350 tbi that is.
Old Oct 16, 2011 | 08:26 PM
platynumx's Avatar
Car: 89 rs vert/88 t/a GTA
Engine: 355 tbi/350 tpi
Transmission: 700r4 w/megashifter/700r4
Axle/Gears: 3.73/???
..As long as it is the chip is from/for(if aftermarket) the same computer(8746 for car tbi if i m not mistaken)
Old Oct 16, 2011 | 09:02 PM
Engine: 5.0 TBI
the chip is from a 1992 chevy caprice 350 tbi
Old Oct 17, 2011 | 11:28 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
might not work, check into that
Old Oct 17, 2011 | 04:34 PM
Engine: 5.0 TBI
caprice use 16136965 as their ecm #
so my 746 ecm wont interchange chips?
MustangBeater20
Oct 29, 2022 09:20 PM
dutch930
Sep 11, 2015 06:58 AM
fonzie85
Aug 13, 2015 11:50 AM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
