tbi regulator help
Old Oct 18, 2011 | 10:28 AM
lynchfrancis's Avatar
tbi regulator help
has anyone ran a single regulated fuel line to the throtlle body and blocked off the stock regulator and put a plug in the fuel return fitting on the back of the throttle bodie. does anyone know if this will work for sure? befor the car was carburated so now i want to put it back to the original conditon and get it running smoth agian, i have a holley bypass style regulator with an fittings for the return and steel beraded lines all ready hooked up, i would rather not change them if the system will work nice
Old Oct 18, 2011 | 11:13 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: tbi regulator help
so you want to go from carbureted back to tbi? fuel injection systems have to have a return line as far as i know
Old Oct 19, 2011 | 11:20 AM
Ronny's Avatar
[IMG][/IMG]
You can see reg next to PS resevoir. Used block off plate for TBI location. Fuel lines are Aeroquip push fit.
db057
Jan 10, 2020 08:55 PM
codeysabatini
Nov 10, 2015 04:07 PM
Glowsock
Sep 11, 2015 11:09 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
lakeffect2
Sep 7, 2015 03:52 PM
