tbi 305
Old Oct 18, 2011 | 10:58 PM
chuck76's Avatar
Car: 1988 convert camaro
Engine: 305 edelbrock performer cam,intake
Transmission: 700r4 shift kit,vett servo,3,4 pack
Axle/Gears: stock
tbi 305
ive got my camaro running again with a 305 with the stock exhaust mans 3" exhaust pipe and cat,eldelbrock rpm intake and eldelbrock performer plus cam, 14" eldelbrock open element air cleaner seems to run good but has that voom sound when i lay into it would that be because its a 305 and has the stock 2.73 gears or is it a sign that i might need to boost up the fuel system.i do plan on making a chip someday to looks like ill need some major help with that to thanks
Old Oct 19, 2011 | 11:29 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: tbi 305
voom sound? so does it fall flat on its face when you get on it? or whats the deal?
Old Oct 19, 2011 | 08:01 PM
chuck76's Avatar
Axle/Gears: stock
Re: tbi 305
its not falling on its face,seems to go but i think it should have a little more spunk ,a better word would be moan than voom(just wasnt clicking in my head what to call it) sounds like the quadrajet
Old Oct 20, 2011 | 09:10 AM
torque_is_good's Avatar
Re: tbi 305
I'm still at a loss?
You have the 700R4 auto and 2.73:1 gears
the vehicle starts in 2nd gear unless you floor it and the TV cable is set correctly. Are you describing the sound that it makes as the engine finally enters the power band?
Please be clear with the description. You may not be having a problem at all. you just might have too high of expectations for a stock smog era vehicle.
Old Oct 20, 2011 | 11:51 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: tbi 305
LT1 cam (roller) are around 20-60$ used.
Old Oct 20, 2011 | 06:29 PM
chuck76's Avatar
Axle/Gears: stock
Re: tbi 305
lt1 205/207 duration @ 50*, .447/.459" lift, 117 Lobe Seperation Angle
eldelbrock Duration Advertised 268° Intake/288° Exhaust Duration @ .050'' 194° Intake/214° Exhaust Lift @ Valve .398'' Intake/.442'' Exhaust Lift dam i didnt look the lt1 would have been the better way to go
Old Oct 20, 2011 | 06:48 PM
chuck76's Avatar
Axle/Gears: stock
Re: tbi 305
how would i know when i should raise fuel pressure and how high of psi
Old Oct 21, 2011 | 04:38 AM
thomas1976's Avatar
Car: 91 Trans am
Re: tbi 305
Can use the dyno simulator program to figure out approx. how much hp, then calculate WOT fuel requirement (I use dynamicefi's exel file). Can post hp # if you need help there.
I doubt playing with the FP alone, will cure the issue, coustom tuning is usually mandatory.
Old Oct 21, 2011 | 07:33 PM
chuck76's Avatar
Axle/Gears: stock
Re: tbi 305
so i have 1228063 ecm should keep this one i c that c.a.t.s. have a kit for $199
Old Oct 22, 2011 | 01:22 PM
thomas1976's Avatar
Car: 91 Trans am
Re: tbi 305
Best is you check compatibility with the seller.
EBL flash, is a better way to go, so you do not have to deal with the slowness and lack of important features of the stock ECM.
Old Oct 22, 2011 | 06:50 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Axle/Gears: 2.73 Open
Re: tbi 305
You really really need to burn a custom chip (as everybody else has said). Also, get a 30psi fuel pressure regulator- it's in the budget TBI build thread
Old Oct 23, 2011 | 11:50 AM
thomas1976's Avatar
Car: 91 Trans am
Re: tbi 305
Over 18psi FP, the coustom chip is mostly useless, requires a way to support VRFP.
Old Oct 23, 2011 | 12:15 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Re: tbi 305
Not sure I quite understand, could you elaborate?
Old Oct 23, 2011 | 02:29 PM
thomas1976's Avatar
Car: 91 Trans am
Re: tbi 305
@ higher FP, the injectors pour out too much fuel, for exemple at idle, a VRFPR will reduce fuel pressure were not needed, but the ECM (including chip) is not configurated to control VRFP.
Old Oct 23, 2011 | 05:11 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Re: tbi 305
Bit of a threadjack, but how should I take care of the fuel delivery problems I'll have with my car after doing all the modifications? I hope the answer isn't EBL flash
Dwayne614
Sep 28, 2015 08:33 AM
LittleFranks
Sep 17, 2015 12:22 PM
CamaroGuy350
Aug 30, 2015 02:56 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
CamaroGuy350
Aug 26, 2015 05:11 PM
