Noob 383 question
Old Oct 19, 2011 | 11:06 AM
infamouz614's Avatar
Car: 1986 Camaro Z28
Noob 383 question
Hey guys, I know this is a noob question (and seeing as I am a noob), and i have looked around the site for the answer and unfortunately my findings werent what i was looking for. So my question is: What EXACTLY does a stroker kit consist of? I have a 350 block with a 2 bolt main that has already been bored out .30 and already been prepped. If someone could provide links for like summit or somewhere I can get a kit for a decent price, ideally under $1000. Im not trying to go too crazy on power, I just need a decent kit that will help me make a decent amount of power. Thanks in advanced all!
Old Oct 19, 2011 | 02:52 PM
bracket rs's Avatar
Re: Noob 383 question
i think my eagle kit was $850.00ish, crank, rods, pistons, rings, bearings, flywheel, should be an eagle dealer in your area.
Old Oct 19, 2011 | 03:18 PM
thanks! that's exactly the information I was looking for!
Old Oct 20, 2011 | 11:53 AM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Eagle has had a somewhat bad reputation for their budget GM cranks breaking the front snout off...hope they fixed that, Scat is another option.
Old Oct 20, 2011 | 12:10 PM
http://www.summitracing.com/parts/SCA-1-92000/
Would that be a good kit to get?
Old Oct 20, 2011 | 01:08 PM
torque_is_good's Avatar
has it been clearanced?
Old Oct 20, 2011 | 05:05 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
First you need to decide what compression you whant and RPM range.
I like http://www.cnc-motorsports.com/ can choose exactly what you need and have it balanced.
I also prefer floating pins over pressed.
Cameeeero
Sep 18, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
redmaroz
Aug 16, 2015 11:40 PM
