No Check Engine Light???
Old Nov 13, 2011 | 03:36 PM
NeNick95's Avatar
Engine: 5.0 TBI
Alright then, so my check engine light hasn't come on, Ive checked the bulb and it was fine so could it be a wire in the dash or something
Will TAke Any Suggestions
Old Nov 13, 2011 | 07:41 PM
ex-x-fire's Avatar
Re: No Check Engine Light???
So it doesn't come on when you first cycle the key?
How did you check the bulb?
You need a wiring diagram, use an ohm meter to test between the bulb socket & ecm(?) terminal, & the other is probably a ground.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
