Researching Good Combo
Old Jan 3, 2012 | 05:49 AM
got_tork's Avatar
Car: 92 RMW
Engine: L05/350
Axle/Gears: 3.23Posi
I have a 4400# 92Roadmaster wagon ,come springtime the L05 is gonna need a overhaul and I wanna do the LT1 cam swap at this time.So the question is do I have the swirl port heads freshened up with a valve job or is there a better stock head for my car?It is a daily driver and doesn' t really see 4000 rpm all that often. But that don't mean it won't with new cam.Currently it has CAI,cop car injectors,AFPR set at 13psi and 3.23 gears
Old Jan 3, 2012 | 06:30 AM
ex-x-fire's Avatar
Re: Researching Good Combo
Vortec heads & intake. Its not a whole lot more expensive to stroke these 350s nowadays.
Old Jan 3, 2012 | 06:57 AM
got_tork's Avatar
Car: 92 RMW
Engine: L05/350
It has to be able to passs emissions test and I'm wanna go the low buck route.
Old Jan 4, 2012 | 11:50 AM
Ronny's Avatar
See Scroggins website.
Pro Products or Pro comp may have a vortec carb manifold/adapter on the cheap. I would not bother with valve job. what does you machinest charge for that?
Old Jan 14, 2012 | 09:34 PM
hatemail72's Avatar
Car: this and Dodge Dakota Quad
Engine: 383 tbi
Transmission: 700 R4
Axle/Gears: 3-73
My engine has died instead of fixining I am biting the bullet and rebuiding the entire thing
305 TBI LO3
head 14102187 need to go but with what
intake 14102189 will this still fit on the new head
what about a cam
I want to dress the engine compartment up but still to look original but more power than the 170 hp
Suggestions
Old Jan 15, 2012 | 07:17 AM
ex-x-fire's Avatar
Instead of fixing it your gonna rebuild it? Sounds like the same thing.
A cheap way to get good power out of a tbi car is swap over to a vortec 350. Put your tbi on it. Way better heads then anything from the early 90s on down. Read the stickies in the tbi section.
customblackbird
Aug 15, 2021 10:16 PM
IMissMy86TA
Aug 31, 2015 08:40 PM
theurge
Aug 21, 2015 12:46 PM
crazynights
Aug 21, 2015 06:53 AM
Fronzizzle
Aug 19, 2015 01:36 PM
