Need some opinions
Old Jan 13, 2012 | 11:43 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
Need some opinions
I have a 91 RS 305 with 91k miles on it, my mpg is progressively getting worse, I'm down to 12 mpg, Ive had the service light on because of the EGR a few times, it has died on me while driving and something does not sound right with the engine/tranny, I currently am laid off of one job and make minimum wage at the other (still in high school) so I don't have money to figure out why these things are happening, can anyone give some advice on what commonly causes these different problems?
Old Jan 14, 2012 | 12:05 AM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
Re: Need some opinions
put a 2x4 under your gas pedal. that may help things out for you.
Old Jan 14, 2012 | 07:45 AM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
I drive it the same way I did when I got it 9 months ago, and I was getting 17-19 mpg
Old Jan 14, 2012 | 07:53 AM
Project-RS's Avatar
whens the last time it had a tune up, oil change, trans flush?
Old Jan 14, 2012 | 08:25 AM
one92rs's Avatar
Car: SOLD!!!!!
replace the coolant temp sensor.
Old Jan 14, 2012 | 08:57 AM
ex-x-fire's Avatar
Is the engine getting up to 190*? If not, that most likely the problem, get a good 195* t-stat. I don't care what anybody says, a cold running efi engine does not get better mpg then a hotter running one does.
Is your air cleaner the stock type? Make sure the hot air tube that hooks to the exh. manifold is good. This aids in mpg in cold weather.
Old Jan 14, 2012 | 12:20 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transflush last summer, oil change 1500 miles ago, I change the cap and rotor and pulled the plugs and wires but they were still good, I have an open element air cleaner on right now and I changed the radiator and coolant and hoses last summer but not the thermostat (which I should have) but it never runs over 200, it's usually around maybe 180ish
Old Jan 14, 2012 | 02:33 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Axle/Gears: 2.73 Open
Could be a bad O2 sensor
Old Jan 14, 2012 | 02:46 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
That's what I'm thinking, once I get back to work that will probably be the first thing a try
Old Jan 14, 2012 | 05:39 PM
ex-x-fire's Avatar
Put the stock air cleaner on for the cold months, get a new t-stat. 195* stat, 180ish is too cool.. Trust me on that.
Make sure the vacuum hose to the map sensor is good.
Old Jan 14, 2012 | 10:10 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Yea I guess I'll put the stock one back on, but I don't have money or time for the thermostat right now, when winters over and I get back to work ill definetly change it if I still have this problem
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Oct 5, 2015 06:23 PM
Jlanz55
Sep 29, 2015 08:55 AM
