How long to pull out a LO3?
Old Jan 16, 2012 | 06:11 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Pulling out my 5.0 TBI motor this weekend also pulling the trans. How long do you think this will take me... not the install just the pull....
Old Jan 16, 2012 | 06:20 PM
Sick92's Avatar
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
Re: How long to pull out a LO3?
In a crammed *** 1 car garage, and taking my sweet time, with also removing everything else under the hood (entire wiring harness,etc), it took me 3 days (5hrs/day) with a t5. This included the engine, harness, trans, torque arm, x member, .....etc.
Was my first time though, and I am very meticulous with things.
I'd imagine it can be done in 5 hours if you hurry your *** off. Biggest things to remove are, fuel lines, torqueconverter bolts (if applies), engine bolts, radiator, a/c lines, ps lines.
Believe it or not, I removed ALL of the engine to trans bolts with a 14mm ratcheting wrench. That was the sweetest engine pull ever.
Old Jan 16, 2012 | 06:25 PM
insomniac's Avatar
Engine: 5.7 L98
im actually hoping to get it all out in about 3-5 hours, i got a full shop, lift, air tools ect....
Old Jan 16, 2012 | 06:31 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Two guys - hydraulic cherry picker, plenty of zip lock baggies and digital pictures on a slopping driveway about 4 to 5 hours (depending on a number of nosy neighbors). What ever you do take your time and label everything. Also, if there an oil - coolant leak things tend to go slower. Bad weather will put a stop to a pull.
Junk yard pulls can be done in about 30 minutes (use of wire cutters and electric impact speeds things up)
//RF
Old Jan 16, 2012 | 06:32 PM
Sick92's Avatar
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
Pft in a shop I've have it out in 2hrs...
Old Jan 16, 2012 | 06:34 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Delete
insomniac's Avatar
Engine: 5.7 L98
everything is going exhaust, harness, ecm , im swapping to a L98 - gonna build the trans while its out. so i really dont have to worry abut saving much...
Old Jan 16, 2012 | 06:42 PM
Sick92's Avatar
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
well save your wiring harness.....it's worth money and not THAT hard to remove once the engine is out.
Literally, remove the 3-4 bolts for passenger kick panel and lower dash support, unplug the connectors there. Remove the c-clip from inside from the black/grey box. And push in the two tabs, and it comes out of the passenger wheel well/fender area.
I literally just did this the other day.....it's super easy.
Old Jan 17, 2012 | 06:46 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
I would remove the tranny first and then pull the engine out with headers and accessories except PS.
5 hours sonds good.
Old Jan 18, 2012 | 05:23 PM
flyinfatman's Avatar
Car: 1991 Firebird
Engine: i have many.
Transmission: WC T-5 from a 1987 GMC 1500
Axle/Gears: 4th gen 10 bolt - 3.23
we did an 8 hour engine swap (blown 350 out, old 305 in) at the track with no power tools or a lift and a cherry picker. You could probably pull it in 5 hours with some help.
Old Jan 18, 2012 | 05:50 PM
torque_is_good's Avatar
the actual pulling it doesn't take long. It's the preparation. If you intend on keeping some things then rusted bolts may slow you down vs using a sawzall and wire cutters.
I had a heck of a time with one ground in the back and ended up cutting and splicing.
remove the engine and tranny together still attached; much simpler
Prodigious
Nov 7, 2020 09:23 AM
777Shock777
Oct 29, 2015 04:30 PM
Ron U.S.M.C.
Sep 7, 2015 08:38 AM
bamaboy0323
Sep 3, 2015 06:07 AM
86White_T/A305
Aug 17, 2015 12:16 AM
