performer tbi intake vs. carbed intake with adaptor
Old Feb 3, 2012 | 11:26 PM
michaelmoore's Avatar
Car: 92 firebird
Engine: L05
Axle/Gears: limited slip
I have been hearing alot of people say to get a carbed intake with an adaptor what makes this better than the performer tbi intake. What are the pros and cons of doing this. Thanks
Old Feb 4, 2012 | 05:03 AM
gmstrong's Avatar
Car: 95 9C1,99 Sierra,90Sierra,00 sierra
Engine: TBI350,LM7,LT1,Vortec 350
Transmission: 700r4,4L60e,4L60e,4L80e
Axle/Gears: 10 bolt,14bolt,3:42,3:73,3:08,3:73.
Re: performer tbi intake vs. carbed intake with adaptor
The only pro i have for the edelbrock is that it looks nice,good things from carbed intake bigger hp gain,cheaper.cons you have make your own tv cable bracket,and have too find a way to mount your coil,bye bye egr,Also you may have to get a chip burned for it to get the most from it.
Old Feb 4, 2012 | 08:21 AM
ex-x-fire's Avatar
Look up the Hot Rod magazine article 'F notes'. Its online, they tested both intakes
Old Feb 4, 2012 | 11:25 AM
Seafarer12's Avatar
Car: 92 GMC K2500 LD
Engine: 350 TBI with some mods
Transmission: NV4500
Just depends on how much work you want to do and how you want things to look. You will get more power out of a 4 barrel but it will be more fabrication and might not look as clean. I am running the performer manifold. I had to lengthen the vacuum line to my power brakes other than that it was bolt in. I painted it black and it looks factory till you get close to it. Cost isnt an issue. I paid 120 for mine on ebay, it had been installed but the engine never ran. It was pretty much new besides a few scratches. I have seen them go for 150 or less pretty regular. To get them most power out of a carbed manifold you need more stuff. If you are running a pretty much stock engine I doubt you would see much difference between the two. Now if you are running aftermarket heads, stout cam, headers and exhaust, bored throttle body, custom prom I am sure you would surpass what the performer could flow.
Old Feb 4, 2012 | 01:54 PM
ex-x-fire's Avatar
Holley has a tbi intake too.
Old Feb 4, 2012 | 02:11 PM
gmstrong's Avatar
+1 on the holley its a great bolt on,plus it has 2" bores.
Old Feb 4, 2012 | 07:11 PM
Shakermaker05's Avatar
Car: 1991 RS
Engine: 305 LO3
Axle/Gears: 2.73's : (
I bought my performer and I was planning on getting the Holly so I bored it out to 2". Though I have yet to put the holly on, I was wondering if anyone has ever done any flow tests as to how a bored performer would hold up against the adapter-carbed intake?
Old Feb 4, 2012 | 07:20 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
i want a taller than stock and better flowing tbi intake to push my air breather up into my cowl hood.
Old Feb 4, 2012 | 10:26 PM
Car: 92 firebird
Engine: L05
thanks guys for your input I think im going to stick to the performer intake
MustangBeater20
Oct 29, 2022 09:20 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
TreDeClaw
Aug 14, 2015 06:58 PM
