New or Remanufactured Flow Matched
Old Mar 9, 2012 | 06:27 AM
OneFast91Vert's Avatar
Car: 91 Camaro RS Vert
Engine: 305 TBI
I'm in the market for a replacement set of TBI injectors but can't decide which is better for me. I'm looking at a brand new set or a set of reman flow matched. Both cost the same amount. I just don't know how important a flow matched set is on a stock L03. I can see if you're using tpi or a high hp tbi build that a matched set is necessary. But I have the mindset that new is better than remanufactured. So what is better in my application?
Old Mar 9, 2012 | 01:31 PM
Ronny's Avatar
Re: New or Remanufactured Flow Matched
FIC injectors is a good place to shop. check them out.
Old Mar 9, 2012 | 04:57 PM
one92rs's Avatar
Car: SOLD!!!!!
i have used this place many a times. only had a problem once. the air freighted me a new injector with a return slip for the bad one.
http://www.injectorwhse.com
Old Mar 10, 2012 | 03:02 AM
Engine: 305 TBI
My question is which should I purchase......reman flow matched or new stock replacements?
Old Mar 10, 2012 | 07:46 AM
one92rs's Avatar
Car: SOLD!!!!!
i have purchased the remans that they said were matched. they are all still in use.
Old Mar 10, 2012 | 02:07 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
I would go with flow matched.
Old Mar 10, 2012 | 03:40 PM
EagleMark's Avatar
Every time I have had injectors serviced they ended up being flow matched. Not so at first test. If you don't have someone in town and can ship yours Mr Injector does great work!
Old Mar 14, 2012 | 11:18 AM
SCCAjunkie's Avatar
Car: 84 Z28
Engine: 91 L98 long block with Pro-jection
Axle/Gears: 91 10bolt w/ 3.42s and T2R
While flow-matched isn't as important in this application, I'd trust a set of rebuilt, flow-matched units, since they've been gone over by "experts" (choose your experts carefully), versus factory units that can have unknown error. If you're doing custom tuning, it's nice to know what you've got.
Old Mar 14, 2012 | 05:39 PM
thomas1976's Avatar
Car: 91 Trans am
Flow-matched is important.
Lets not forget the dual-plane intake, each injector fuels 4 cylinders.
Old Mar 15, 2012 | 06:55 AM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Axle/Gears: 2.73 Open
I'll second that. Great rates, effective service and quick turnaround- can't go wrong with Mr. Injector
Old Mar 15, 2012 | 10:06 AM
Ronny's Avatar
which four? Is it L bank R bank?
Old Mar 15, 2012 | 10:44 AM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
This is a solid reason why single plane intakes work well with TBI's. The other reason would be that intake velocity doesn't matter as much when using fuel injectors
Old Mar 16, 2012 | 04:20 PM
thomas1976's Avatar
Car: 91 Trans am
R injector, cylinder 1 7 4 6 and L injector 3 5 2 8
Old Mar 19, 2012 | 10:08 AM
Ronny's Avatar
Yes I am aware of that.
But how do we know when one of two injector fires it is positioned over the correct bank?
Maybe it does not make a difference being a wet system?
360d of crank rotation each injector fires once during cycle
Old Mar 19, 2012 | 01:49 PM
thomas1976's Avatar
Car: 91 Trans am
I look at it the easy way.
Flow matched injectors is the only way to have the most equal amount of fuel available for each cylinder.
Pac J
May 17, 2020 10:44 AM
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
rusty vango
Sep 29, 2015 02:44 PM
dusterbd
Sep 29, 2015 08:40 AM
