BB tbi injectors
Old Apr 9, 2012 | 06:21 AM
dragracer1586's Avatar
BB tbi injectors
Hey guys I have a TB from a 454 and have noticed that there are 3 different injectors for them. Do they each require a different fuel pressure?? I did do a search but didn't see anything..
I am in the process of building a 383 for my truck and just need to know if a fuel pump is needed to keep everything happy.
Old Apr 9, 2012 | 07:07 AM
gmstrong's Avatar
Car: 95 9C1,99 Sierra,90Sierra,00 sierra
Engine: TBI350,LM7,LT1,Vortec 350
Transmission: 700r4,4L60e,4L60e,4L80e
Axle/Gears: 10 bolt,14bolt,3:42,3:73,3:08,3:73.
Re: BB tbi injectors
I would get a adjustable fuel pressure regulator.
Old Apr 9, 2012 | 07:12 AM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
i'd put a walboro 255 pump in jus to be safe . i've always had good luck with them .
Old Apr 9, 2012 | 07:23 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Yes will require different fuel pressures and tune, as they provide different amounts of fuel @ equal pressure, scroll down http://dynamicefi.com/TBI_Fueling.php
Try typing the #on your injectors in the search function, should be some good imput.
Old Apr 9, 2012 | 07:34 AM
thomas1976's Avatar
Car: 91 Trans am
TPI pump would be a better choice. Keep in mind, the return system is not conceived to flow huge amounts of fuel back to the fuel tank. And a walbro 255 @ only around 20 psi will flow a huge amount of fuel.
Old Apr 9, 2012 | 07:37 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
i don't know much about his trucks fuel system . i believe in overkill with a fuel system so i'd up grade the return lines then an run the bigger pump . better safe than sorry . just my opinion
Old Apr 9, 2012 | 07:46 AM
thomas1976's Avatar
Car: 91 Trans am
The TPI pump is safe up to around 450hp.
ACD#241 TPI pump delievers 40 GPH = aprox 150 LPH. (PSI shutoff 65-75)
In theory that's good for 480hp, hp = flow rate (gph) * 12
Another nice internet formula.
HP divided by 2 = lbs./ hr
lbs./hr divided by 6 = GPH (minimum)
multiply GPH by 1.15 for safety.
Old Apr 9, 2012 | 08:51 AM
Hey thanks for the help guys!!!!!! This will be almost a daily driver but more so to tow my race car in an enclosed 24" trailer and looking to get close to 400hp..
Trying to come up with a plan as it has a 4l60E trans as it's a 94 C2500 2wd and see from reading here it has a better puter in it than the early years.
Looking for about 9 to 1 compression with a forged dished piston and a factory roller cam from a caprice police car..
Any help at all is appreciated!!!
Old Apr 10, 2012 | 12:35 PM
thomas1976's Avatar
Car: 91 Trans am
Originally Posted by dragracer1586
looking to get close to 400hp ... Looking for about 9 to 1 compression with a forged dished piston and a factory roller cam from a caprice police car
In this case make sure you do not have the 46 #/hr BB TBI injectors, they will never flow anough.
Exemple with 80 #/hr injectors @ 23 psi fuel pressure, would support 400 fwhp and require 35 GPH.
A police caprice cam sounds too mild to produce 400 fwhp in a 383. Were did you get that #?
Old Apr 11, 2012 | 05:39 AM
Thomas,Just had a brain fade but looking for 300+ hp sorry. I have a BB tbi that has 17104288 injectors in it. So do you think those will support this kind of HP with having an adjustable regulator??
Old Apr 11, 2012 | 07:02 AM
thomas1976's Avatar
Car: 91 Trans am
17104288 injectors appear to be 94-95 7.4L TBI trucks (230-255 hp) 45lb/hr injectors.
https://www.thirdgen.org/forums/post...188-post2.html
For 300 fwhp I would use the 350 TBI 61-68 #/hr injectors, requires around 25 psi and VRFPR.
Or could try the 75 #/hr @ around 17 psi with AFPR.
Old Apr 12, 2012 | 11:13 AM
Thanks Thomas, So your saying that the injectors with the BB TBI that I have will need different injectors..
Old Apr 12, 2012 | 12:04 PM
thomas1976's Avatar
Car: 91 Trans am
The 45 #/hr injectors @ around 30 psi are ok for the 230-255 hp the BB produced.
But they would need to be run @ around 45 psi to support your 300 fwhp engine.
Personally I have no experience running these injectors with such high fuel pressure.
Old Apr 12, 2012 | 02:36 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
i'm pretty sure 30 psi max. on those injecters . 30 psi on 55 lb hr injecters should be enough for 316 fwhp . as calculater by my ebl utility . 61 lb hr injecters at 30 psi are good for 350 fwhp an 80 lb hr injecters are good for 459 fwhp at 30 psi ....
Old Apr 12, 2012 | 04:35 PM
thomas1976's Avatar
Car: 91 Trans am
How do you come to that conclusion?
Old Apr 12, 2012 | 08:07 PM
Thanks guys, Where can I get the part #s for 55 or 61lb injectors??
Old Apr 13, 2012 | 01:28 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
i'm pretty sure i read somewhere that 30 psi of fuel pressure is the max safe limit for tbi injecters .
Old Apr 13, 2012 | 06:27 AM
thomas1976's Avatar
Car: 91 Trans am
Please do us a favor and post the link of the place, were you'r pretty sure you got that information from.
Old Apr 13, 2012 | 06:28 AM
thomas1976's Avatar
Car: 91 Trans am
Did you try a search?
Exemple:
55 #/hr - GM5235279
80 #/hr - GM17084304
And these work @ over 30 psi too, if it needs to be.
Old Apr 13, 2012 | 06:40 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
i'm curious what your doubting ? do you think 30 is to high or to low ?
heres one where people are talking about running higher than 30 psi :
https://www.thirdgen.org/forums/tbi/...-pressure.html
i've read so much on these things can't quite place the link . my ol computer with all the saved links crashed . hopefully someone else will chime in on this tho . i'm sure up to 30 psi is safe after that i don't know
but i'm sure my calculations for the different injecters are correct since i used the ebl flash utility
Old Apr 13, 2012 | 06:50 AM
thomas1976's Avatar
Car: 91 Trans am
Well that tread confirms that they can be run @ over 30 psi. I myself have run 35 psi.
I thought you may have some prof of someone having injector issues @ over 30 psi.
Old Apr 13, 2012 | 07:49 PM
Thanks again, Where can one buy a set of injectors that are useable and not junk with out going to the dealer??
Old Apr 14, 2012 | 01:25 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
i'm gonna buy a 454 tbi off ebay ...
Old Apr 15, 2012 | 03:30 AM
thomas1976's Avatar
Car: 91 Trans am
This is a tgo member http://tbiparts.com/
Or get a set anywere and have them tested http://www.witchhunter.com/
Old Apr 15, 2012 | 07:29 PM
Thanks Thomas for those links!!
MustangBeater20
Oct 29, 2022 09:20 PM
pimp2303
Jul 27, 2017 02:03 PM
Keith5
Aug 27, 2015 04:37 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
